975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 11:10 PM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Kastan Pro Full Cro-Mo
Author Topic: Kastan Pro Full Cro-Mo  (Read 10017 times)
Offline Gnarlyscoots
  • BANNED
Re: Kastan Pro Full Cro-Mo
« Reply #25 on: January 04, 2014, 10:48 PM »
Terry I have one of these with the forks.... I'm 99% the forks are 1" non-threaded
The head has skims to take and 1" headset or without it will take 1" 1/8, I think that was the case but I will check tomorrow.
Bru  :daumenhoch:
Thanks Bru. If that is the case, could I not just buy a 1 1/8 threaded headset? Would that fit a 1" fork?
Sounds dumb but new to this malarky  :D   ;D
BANNED
Offline nic968
« Reply #26 on: January 04, 2014, 11:35 PM »
 You may have one of the frames that took a 1" cup at the top and a 1 1/8" at the bottom...Sounds weird, but Kastan did make some 'transition' frames and forks that took a regular shafted stem on top, yet had a thicker crown I think..
 Did you check top and bottom measurements? If they're the same, it maybe 1 1/8" all the way, which could work out easier in the long run..( Apart from the GT forks..)
  • BANNED
« Reply #27 on: January 04, 2014, 11:44 PM »
I have just measured the interior diameter of the top and bottom of the head tube and it comes to 33.5/34mm. Is that 1 1/8?
If so, Jon has found some reducer shims on the bay which will enable to carry on as planned  :daumenhoch:
BANNED
« Reply #28 on: January 04, 2014, 11:55 PM »
Sweet,sweet frame Tel  :daumenhoch:
Love owt Kastan, the uni blade fork and hub set up  with the 4 piece bars is just mentally cool  :smitten:
I'll be keeping an eye on this  :coolsmiley:
Offline nic968
« Reply #29 on: January 04, 2014, 11:57 PM »
 If they're both the same, and too baggy for the beartrap, then it's a 1 1/8" frame..You could use 1" threaded forks using a regular headset with shims if your set on using 1" threaded forks..
 I went through the same thing last year after being sold a 1 1/8" frame as a 1", but I've opted for the 1 1/8 route.. :)
Offline oldtired
  • Dirty Old Man
« Reply #30 on: January 05, 2014, 12:34 AM »
so it was the frame that was machined for the different headset cups ........ cool  i thought the headset race and machining on the forks was where the adaption was made ,    learn somat new every day  :daumenhoch:  only saw one bit90's and that was well battered by a Barnsley street monkey  ;D
defo with Dubber though looking forward to seeing this one
rodriguez
« Reply #31 on: January 05, 2014, 02:05 AM »
No and Yes
1 1/8" = 28.6mm but 34mm is the correct head tube inner diameter for a 1 1/8" threadless set up.
Minor set back  :daumenhoch:
Nice frame   :coolsmiley:
http://sheldonbrown.com/cribsheet-headsets.html
http://www.ebay.com/itm/Pair-of-Alloy-Headtube-Headset-Reducer-Shims-1-1-8-to-1-/400586491917?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item5d44d0c80d
« Last Edit: January 05, 2014, 02:09 AM by rodriguez »
  • BANNED
« Reply #32 on: January 05, 2014, 09:31 AM »
Shims ordered buddy and I will be using my genuine BT II for now. I'm going to try and track down an Odyssey Pro headset but not at the stupid money like the one on US Ebay  :D
These are my fork options. Going with the GT because the Eagle claw drops and the welding is superb  :daumenhoch:
1994 dated NOS Fork
1993 dated Pro Series Fork
« Last Edit: January 05, 2014, 09:45 AM by Londonhellboy »
BANNED
Offline midschooljon
    • Make Your Bones
« Reply #33 on: January 05, 2014, 09:43 AM »
Pros Series fork all day long.  :daumenhoch:  :smitten:
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
  • BANNED
« Reply #34 on: January 05, 2014, 10:30 AM »
I think you're bang on there Jon  ;D
BANNED
Offline fischflo
« Reply #35 on: January 05, 2014, 12:20 PM »
Incase you're looking for a 1 1/8th headset......
40$ + 14$ (maybe 25) s/h for OdyPro ->http://www.bicyclebuys.com/item/1603007PART/odyssey-pro-headset-1-1-8
« Last Edit: January 05, 2014, 12:40 PM by fischflo »
  • BANNED
« Reply #36 on: January 05, 2014, 01:14 PM »
Really nice that is Bru  :smitten:
BANNED
Bru
« Reply #37 on: January 05, 2014, 01:21 PM »
Ta  :)
Need to get my ass in gear and finish it, not 100% sure about the bars... Don't know what tyres to put on it, what brake would be right, what lever and grips to use  :-\
Never had so many issues before!
Bru  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #38 on: January 05, 2014, 02:54 PM »
nice that  :daumenhoch:
bars are easy kastan 4 piece  :daumenhoch:    there's a set of Mosh cranks on ebay at the mo with a kastan spindle  :daumenhoch:
  • BANNED
« Reply #39 on: January 06, 2014, 02:02 AM »
Seat clamp. Will get just a sympathetic clean  :daumenhoch:
BANNED
  • BANNED
« Reply #40 on: January 06, 2014, 10:29 AM »
Seat clamp cleaned up a little and going to go with the DX brake. I also have the matching lever, lefty too  :daumenhoch:
BANNED
Offline Julian347
« Reply #41 on: January 06, 2014, 10:57 AM »
Terry,
Have a look at this article about Winnie Wright RIP. He was riding a Kastan in the mid 90's before he had the Pashley.
http://www.fatbmx.com/bmx/news/article.php'storyid=15475
  • BANNED
« Reply #42 on: January 08, 2014, 11:04 AM »
Right guys. I got hassle here  :yahoo_silent:
My head tube inside diameter is 34mm (give or take),
a standard headset cup for 1" fork is 32.7mm.
I fitted these shims and tried to fit the headset but it wouldn't, so I measured the inside diameter of the shim and it is 30mm (give or take).
Is a 'mini' headset cup 30mm ??? If so, then that is what these shims are for and I am back to the drawing board  :(
« Last Edit: January 08, 2014, 11:27 AM by Londonhellboy »
BANNED
« Reply #43 on: January 08, 2014, 11:30 AM »
Road bike 1" headset cups are 30mm
« Reply #44 on: January 08, 2014, 11:32 AM »
Std cup 1 1/8 headsets are 34mm at insertion point
  • BANNED
« Reply #45 on: January 08, 2014, 11:42 AM »
Thanks Si. Would you know where I can get some shims, 1 1/8 to 32.7mm ???
BANNED
« Reply #46 on: January 08, 2014, 12:00 PM »
« Reply #47 on: January 08, 2014, 12:01 PM »
Or might you be better with an 1 1/8 fork?
  • BANNED
« Reply #48 on: January 08, 2014, 12:04 PM »
Once you have the right headset,It's the steerer that needs a shim isn't it, 1" - 1 1/8"?
http://www.evanscycles.com/products/m-part/threadless-stem-shim-adapter-ec039894?country=GB&currency=GBP&utm_content=mkwid__pcrid_17321847296_kword__match__plid_&gclid=CN_83qTD7rsCFc3KtAodex4ApQ
No, that's going the other way round. I need to reduce my 34mm headtube to accept a 32.7mm headset cup. Maybe a Uni seat post shim would do the trick? It needs to be approx .5mm to 1mm thick.
My mate in the US has the headset that came off this frame but the lower cup has a crack in it.
As I have already bought the fork, headset and stem for this, I didn't want to go down the route of having to buy more and try and sell what I have, if that makes sense  :-\
« Last Edit: January 08, 2014, 12:11 PM by Londonhellboy »
BANNED
