975759 Posts in 138934 Topics by 6360 Members - Latest Member: TattooedYorkie September 28, 2024, 12:21 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Pro Brake Fin for under £2 from Wilko's
Author Topic: Skyway Pro Brake Fin for under £2 from Wilko's  (Read 1010 times)
Offline Funkyworm
« on: December 28, 2013, 04:55 PM »
Ok so Skyway pro brake fins can be bloody expensive & it can be difficult tracking them down.
This might have been posted before but I think i've come up with a solution (cosmetic at least) to save you from having to spend a fortune not to mention the time to hunt these little buggers down.  be it for use on the Brake pad itself (or) for use as a ((((spacer/washer)))) to be used on a flat rear brake bridge which seems to be a common use for these things.
Cosmetically they look great & I honestly i can't see why this wouldn't work .
All you need are these from Wilko's,  I think they were 89p a pack. The M6 30mm come in packs of 4 & the smaller washer come in 18's so for a full set of 4 brake pads you'll need one pack of these &  3 of the 30mm.
& layer them up
& there you have it  (Et Voila) :daumenhoch:
« Last Edit: December 28, 2013, 05:00 PM by Funkyworm »
Re: Skyway Pro Brake Fin for under £2 from Wilko's
« Reply #1 on: December 28, 2013, 04:57 PM »
That is very clever, great work.  :4_17_5:
« Reply #2 on: December 28, 2013, 05:19 PM »
smart arse!    :LolLolLolLol:
but what if I want some red anoed' ones...   :coolsmiley:
Offline Funkyworm
Offline chubby
  • Needs Pegs
« Reply #4 on: December 28, 2013, 05:30 PM »
TA DAAAAAA  :2funny:
« Reply #5 on: December 28, 2013, 05:52 PM »
Brilliant  :4_17_5:
Offline Glynnyboy
« Reply #6 on: December 28, 2013, 06:25 PM »
That looks pretty  8)
Offline oldtired
  • Dirty Old Man
« Reply #7 on: December 28, 2013, 07:10 PM »
 :LolLolLolLol:  love it  :daumenhoch:
Offline solow79
« Reply #8 on: December 28, 2013, 08:19 PM »
I used that vht paint. Spot on colour when I sprayed it on, but, after following instructions I baked the sprayed item to toughen the finish it came out a burnt orange colour. F*ck knows what went wrong. Probably not a 100% clean oven. :-[
