975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 03:38 AM
RADBMX.CO.UK  |  Mid School BMX (>87) 1989 to 2003 (<05)  |  Mid School ( Keep the faith )  |  Odyssey Sprocket Pocket Question
Author Topic: Odyssey Sprocket Pocket Question  (Read 1115 times)
Offline GavinDavis
« on: December 07, 2013, 07:26 AM »
Has anyone ever used an Odyssey Havok Sprocket Pocket with a 3 piece crank?
Ive put the sprocket pocket onto an oddy torque converter and a GT chainring and it looks as though it will only be able to support a 1 piece crank?
Any pics of your setup would be awesome :)
Offline kev-s
Re: Odyssey Sprocket Pocket Question
« Reply #1 on: December 07, 2013, 08:32 AM »
yes its been done before but u have to cut the pocket sprocket so it fits between the crank arm :daumenhoch:
Offline GavinDavis
« Reply #2 on: December 07, 2013, 09:01 AM »
Hmmm thats definitely not something I wanna do as the pocket is pretty mint.
I didnt realise they couldnt naturally take a 3 piece :(
Offline kev-s
« Reply #3 on: December 07, 2013, 09:29 AM »
what crank are you running?
i think u may get away with a redline flight crank arm as they are quite square and flat
pretty sure u cant use a profile crank arm unless you cut the pocket sprocket due to the arm being more round
Offline GavinDavis
« Reply #4 on: December 07, 2013, 09:47 AM »
You might have guessed...Profile lol.
Maybe if I space it out slightly from the powerdisc then it might clear the pocket bolt? Ill give it a try anyway.....doh!
Offline Dannywhac
  • return of the whac
« Reply #5 on: December 07, 2013, 11:12 AM »
You've gotta cut it Gav to use it with a Profile arm. If you space it the sprocket bolt needs spacing as well (that is if it'll reach). If it's just a show bike then space away, if you're gonna ride it cut the Sprocket Pocket :)
If you get a power disc that has the crank bolt hole exactly in the middle of two chain ring bolts (rather than the normal slightly offset ones) then it fits better and you don't loose a SP bolt by cutting  :daumenhoch:
Offline GavinDavis
« Reply #6 on: December 07, 2013, 12:56 PM »
Damn it lol.
Its for the WAL so I guess I can always go for an OPC.....even Ron ran an OPC on his WAL back in the day so it may be ok to choose that as an easy option.
All I would ever do is lightly ride it/roll it around as it took me too long to find it to consider breaking it lol.
Appreciate your advice though chaps  :daumenhoch:
I might put the Profiled on the Big Daddy instead....which will definitely be a rider! :)
Offline kev-s
« Reply #7 on: December 07, 2013, 01:03 PM »
if your only lightly riding it then id try to source a mtb profile axle as they are longer and profile also do longer sprocket bolts, then just space it out
aslong as your not cranking it everywhere it will be fine :daumenhoch:
Offline GavinDavis
« Reply #8 on: December 07, 2013, 01:15 PM »
Another interesting option Kev.....nice one buddy  :daumenhoch:
Offline john4130
« Reply #9 on: December 07, 2013, 01:22 PM »
it needs to be cut for redline 401s, had one on my standard lengthy.
