975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 06:35 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hutch Pedal Reflector Help
Author Topic: Hutch Pedal Reflector Help  (Read 1053 times)
Offline wilsey72
  • Thats corn that is.
« on: November 13, 2013, 04:03 PM »
Can anyone assist with where to get replacement reflectors for these.... Cheers Ta.
GLOUCESTER RIDE 28th July 2018
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
Re: Hutch Pedal Reflector Help
« Reply #1 on: November 13, 2013, 05:25 PM »
From a pedal reflector shop
Offline steve69
  • aka. Steve Changa
« Reply #2 on: November 13, 2013, 09:05 PM »
As far as I'm aware your pedals were made by SR, so it's possible that other SR pedals share the same reflectors such as Custom M's etc which maybe easier to find  :-\
I'll have a look in my spares for you  :daumenhoch:
Offline wilsey72
« Reply #3 on: November 13, 2013, 09:15 PM »
Tried that but the one local to me sold out.
Thanks for your valuable input though... :daumenhoch:
Offline wilsey72
« Reply #4 on: November 13, 2013, 09:21 PM »
 :bow:
Offline Bfellows
« Reply #5 on: November 13, 2013, 09:42 PM »
If you can measure the distance between the fixing lug centres and overall approximate size I'll check if SR will fit for you.
Offline wilsey72
« Reply #6 on: November 14, 2013, 10:16 AM »
Thanks a million, the lug centres are 25mm, overall length is 55mm, height is 15mm.
I really appreciate your assistance.  :daumenhoch:
« Reply #7 on: November 14, 2013, 12:44 PM »
try rummaging in bins - that's where all reflectors* should be thrown at the first opportunity
you never know what else you might find, things that the everyday folk leave behind
* unless it's a burner - they seem to be exempt from this rule
Offline wilsey72
« Reply #8 on: November 14, 2013, 01:04 PM »
I keep telling my kids 'be safe be seen' so should practice what I preach...   :-[
Offline fischflo
« Reply #9 on: November 14, 2013, 01:48 PM »
http://www.ebay.co.uk/itm/Bicycle-Pedal-Reflector-4-pcs-Bike-Cycle-Cycling-Reflectors-Set-/131021646568
"    Replacement pedal reflector
    4 pcs
    55mm x 15mm
    c-c srew -23mm(standard size)" :surprise:
Offline steve69
  • aka. Steve Changa
« Reply #10 on: November 14, 2013, 01:54 PM »
Yep, got a set in that size if you want to PM me your address  :daumenhoch:
Offline wilsey72
« Reply #11 on: November 14, 2013, 08:33 PM »
Thanks Fischflo I saw these too but don't like the nut fixings, I believe they should be the push in type.
Steve PM'd you mate.  :daumenhoch:
Offline fischflo
« Reply #12 on: November 15, 2013, 07:52 PM »
push in, of course :slayer:
