tech 4s ?!?
Quote from: fischflo on November 11, 2013, 12:29 PMtech 4s ?!?I hope it's tech 4s - they're Chris' favourite levers
Quote from: griff on November 11, 2013, 12:35 PMQuote from: fischflo on November 11, 2013, 12:29 PMtech 4s ?!?I hope it's tech 4s - they're Chris' favourite levers Looking at the position of the rivet i'd say Tech 3 (sweating emoticon)...
Quote from: Jaan on November 11, 2013, 12:42 PMQuote from: griff on November 11, 2013, 12:35 PMQuote from: fischflo on November 11, 2013, 12:29 PMtech 4s ?!?I hope it's tech 4s - they're Chris' favourite levers Looking at the position of the rivet i'd say Tech 3 (sweating emoticon)...There's one on Museum running a lovely set of Tech 4............ http://bmxmuseum.com/bikes/jmc/65694
Shifter has DX lever
Thanks Sean, would you say the rear is laced 4x? Would it then make sense that the front would be too? I always thought 4x was more for freestylers?
Quote from: Jaan on November 12, 2013, 06:32 PMThanks Sean, would you say the rear is laced 4x? Would it then make sense that the front would be too? I always thought 4x was more for freestylers?What I think he is running is 4x racelace, this is where all of the spoke heads face inwards.
Quote from: stidds on November 12, 2013, 06:40 PMQuote from: Jaan on November 12, 2013, 06:32 PMThanks Sean, would you say the rear is laced 4x? Would it then make sense that the front would be too? I always thought 4x was more for freestylers?What I think he is running is 4x racelace, this is where all of the spoke heads face inwards.Mmm, i'm not sure how to do that having only ever laced one set of wheels
Quote from: Jaan on November 12, 2013, 06:48 PMQuote from: stidds on November 12, 2013, 06:40 PMQuote from: Jaan on November 12, 2013, 06:32 PMThanks Sean, would you say the rear is laced 4x? Would it then make sense that the front would be too? I always thought 4x was more for freestylers?What I think he is running is 4x racelace, this is where all of the spoke heads face inwards.Mmm, i'm not sure how to do that having only ever laced one set of wheels Ask and you will receive....http://bmxmuseum.com/forums/viewtopic.php?id=255583
He wore brown Y fronts.
