975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 04:09 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  forks
Author Topic: forks  (Read 472 times)
Offline scott4315
forks
« on: November 10, 2013, 05:19 PM »
I've tried to put some spoke wheels on my old school hawk bmx but the front forks aren't wide enough do the wheels come in different widths as the mags fitted fine
Re: forks
« Reply #1 on: November 10, 2013, 09:51 PM »
You can find that some hubs are slightly different in size - and the width of the axle parts can make a difference
Some times forks can be tight - but if you can prise apart the forks a bit, you should be able to get the hubs in there
Or you could find some slimmer axle washers and then the forks might work better
if you still have trouble - post some pic's and we can go from there  ;)
hope this helps - cheers B  :D
Offline scott4315
Re: forks
« Reply #2 on: November 11, 2013, 08:20 AM »
Thanks I'll try it today
