975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:54 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  back brake prob
Author Topic: back brake prob  (Read 2033 times)
dannyboy
back brake prob
« on: September 07, 2005, 07:20 PM »
ive just got a master frame and forks and have stipped a super tuff burner to use the bits on it ive fitted all the parts apart from the rear dia comp brake as on the burner the cross member is a plate and on the haro it is a tube so the bolt wont fit throgh the tube can i get a longer bit or do i need to buy a nos rear brake with a longer bolt ?cheers :(
Offline Rombloke
  • do one
Re: back brake prob
« Reply #1 on: September 07, 2005, 07:24 PM »
local bike shop should be able to sell you a bolt with a longer reach, if not post somthing up in the wanted section on here geezer
Dave
haro, how do you do
dannyboy
Re: back brake prob
« Reply #2 on: September 07, 2005, 10:49 PM »
cheers
Re: back brake prob
« Reply #3 on: September 07, 2005, 11:18 PM »
Has the bolt been sawn down or something, the standard rear DC should fit through the tube
