975808 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 06:39 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Kool caps
Author Topic: Kool caps  (Read 537 times)
Offline jordanjordan
Kool caps
« on: November 09, 2013, 02:02 AM »
some Kool caps cover the whole plastic area near the hub but on mine you can see some of the plastic (where it should be metal) what can i put there to cover the plastic ? the others use adhesive metal strips is it possible to make my own (how?) or is there an alternative
thanks
Re: Kool caps
« Reply #1 on: November 09, 2013, 05:01 PM »
you can either make a cap that fits around it or some foil tape - if it's the new alloy caps that you have bought
Offline Munnyella
Re: Kool caps
« Reply #2 on: November 10, 2013, 12:03 PM »
you could get some silver spray and paint the hub centres before you stick the caps on, with a good match, thats gonna look more`authentic' than sticking bits of tin on!
or buy my graphites with gold kaps already on, not an issue with graphs' because they are metal hub centres!!
MM
