976212 Posts in 138990 Topics by 6420 Members - Latest Member: churchclothes March 29, 2026, 09:34 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  shimano DX hub Q:
Author Topic: shimano DX hub Q:  (Read 987 times)
shimano DX hub Q:
« on: November 07, 2013, 10:29 PM »
On a Shimano Hub with the quick release cog - just need to know which way around the parts go
so cog side pointing right - plastic spacer - then cog (curve to outside or in ?) the clip - is that right ?  ???
any pic's would help
and I take it that the design allows it to rattle a bit ?
cheers B  ;)
Offline VOIVOD
Re: shimano DX hub Q:
« Reply #1 on: November 08, 2013, 08:44 AM »
 :) Shouldn`t rattle-the cog should be pretty snug.Plastic spacer on first,then cog then lockring.You can buy placcy spacers in 2.5mm or metal ones in 1,1.5 or 2mm if you need to perfect the chainline.
