975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 26, 2024, 11:57 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Z Rim Split
Author Topic: Z Rim Split  (Read 1364 times)
Z Rim Split
« on: November 03, 2013, 10:06 AM »
Gotta Z rim with a split, maybe an inch and a half, anyone ever tried to do a repair, it will go on a show pony, so might just try to hide ?
Re: Z Rim Split
« Reply #1 on: November 03, 2013, 10:53 AM »
Never done it Nick but would think heating it up..  blowtorch fook yes...would be the way to go
Re: Z Rim Split
« Reply #2 on: November 03, 2013, 10:55 AM »
Blowtorch.......like it
Offline That Swan Guy
Re: Z Rim Split
« Reply #3 on: November 03, 2013, 10:57 AM »
Re: Z Rim Split
« Reply #4 on: November 03, 2013, 11:19 AM »
Epoxy resin glue type stuff?
Re: Z Rim Split
« Reply #5 on: November 03, 2013, 11:36 AM »
hot knife and seal the top and then sand and cover up  ;)
Re: Z Rim Split
« Reply #6 on: November 03, 2013, 12:29 PM »
I don't think it melts to form the 2 sides together,  I tried it once with a heat gun and it just blistered,  I would say pony only unless your prepared to really fook it up....   ;)
Offline Peter J
  • I have issues
Re: Z Rim Split
« Reply #7 on: November 03, 2013, 12:37 PM »
Clean the split and slide in a little epoxy and nip up with a G clamp  ;)
Re: Z Rim Split
« Reply #8 on: November 03, 2013, 01:16 PM »
Yep, might get some glue and a clamp, see if that works  :daumenhoch:
Re: Z Rim Split
« Reply #9 on: November 03, 2013, 05:58 PM »
get the fookin blowtorch on it :LolLolLolLol:
Re: Z Rim Split
« Reply #10 on: November 03, 2013, 06:39 PM »
Are they Nylon? Its a thermoplastic and generally the only way of bonding it is fusing it with heat. Getting the right temp to fuse and not melt though could be tricky  :(
Offline Sid1972
  • Bloody kids bikes... : )
Re: Z Rim Split
« Reply #11 on: November 03, 2013, 10:28 PM »
Send it me Nick, I have some glue at work that fuses plastics together. It dries totally clear and I inject it so less chance if damaging the rim getting enough in to bond it together.  ;)
Offline Sid1972
Re: Z Rim Split
« Reply #12 on: November 03, 2013, 10:34 PM »
It's called 'tensol 70' if u prefer to have a go yourself.  :daumenhoch:
Re: Z Rim Split
« Reply #13 on: November 04, 2013, 12:33 PM »
I reckon the best way to fix it is to organise a prayer group and start praying  :LolLolLolLol:
Re: Z Rim Split
« Reply #14 on: November 04, 2013, 01:43 PM »
You'll find that group on Facebook  :daumenhoch:
Offline Gizmo
Re: Z Rim Split
« Reply #15 on: November 05, 2013, 07:22 PM »
Put it in the freezer  ;D
Offline Jt
Re: Z Rim Split
« Reply #16 on: November 05, 2013, 09:20 PM »
Superglue.
Clamp.
3 large vodkas and a hail mary.
Quick sand and away you do.
Man on a galloping horse and all that.
Re: Z Rim Split
« Reply #17 on: November 05, 2013, 09:25 PM »
Yep, that sounds the ticket JT  :daumenhoch:
