975810 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 04:52 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Seat post shims
Author Topic: Seat post shims  (Read 772 times)
Offline stevepeanut
Seat post shims
« on: October 24, 2013, 06:33 PM »
I been having trouble with a seat post shim on my lasses burner. Its a mk1 burner with the larger diameter seat post size so I got a shim to convert it to 22mm.
I was using it this way, dropping the shim into the seatpost, then putting the clamp over the top, but when I do this, it seems to be putting more pressure on the shim rather than the frame. Is this the correct way to use it?
Or is this the correct way? putting the clamp on first then dropping the shim over the top, its loosly fitted but the picture should show the idea. I am thinking the first way looks correct, but this 2nd way could possibly put more pressure on the seatpost frame tube rather than the shim.
Offline garran
Re: Seat post shims
« Reply #1 on: October 24, 2013, 07:15 PM »
we used to do it the 2nd photo way
Offline mattuknc
Re: Seat post shims
« Reply #2 on: October 24, 2013, 07:17 PM »
^^ the bottom one, doesn't look as 'neat' but does the job as it should.  :daumenhoch:
'15 PK Ripper - '13 Mankind Action - '12 Skyway TA XL - '04 King Bike Co Trial - '02 Hoffman EP -  '83 Mongoose Expert
Offline stevepeanut
Re: Seat post shims
« Reply #3 on: October 24, 2013, 09:05 PM »
Tried it the 2nd way, filed the clamp so it fits perfect, nipped it up, then dropped the shim in, followed by the post, locked solid now, loads better  :)
