975755
TattooedYorkie
September 22, 2024, 10:40 AM
Anyone ever worked with carbon fibre?
Topic: Anyone ever worked with carbon fibre? (Read 643 times)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
October 23, 2013, 10:47 PM »
Got an idea
and know the principle behind it all, even seen a few catamarans etc built on how its made
but hoping some of you lot work or have experience with it
Re: Anyone ever worked with carbon fibre?
October 23, 2013, 10:50 PM »
I can see where this is going!
Looking forward to the Ace carbon wheelset
brettypeeps
Team Admin / Mechanic
My life is Radbmx
Posts: I am a geek!!
October 23, 2013, 11:47 PM »
I have worked with Carbon fibre in a structural manner on Harriers. If you get it right then it is good get it wrong and it is so brittle.
BMX wheels good luck
http://bmxmuseum.com/user/27524/bikes
oldschoolace
Team Moderator
Double Flip Whip
Bodger
October 23, 2013, 11:54 PM »
Got bigger plan then wheels this time guys
Just wondering whether layering it up in a negative mold or forming it round a dense Polystyrene shape and vacuum bagging it would be a better option?
brettypeeps
My life is Radbmx
October 24, 2013, 12:07 AM »
Are you going to use pre preg?
Or try and mix your own. The resin will normally react with Polystyrene. We used to use heat lamps to get it to set correctly but the big problem is getting it laid up with delam. a vacum cam help with that as you have already said
oldschoolace
Team Moderator
Double Flip Whip
Bodger
October 24, 2013, 12:16 AM »
Just looking into the options at the mo but just found a guy in the states who built his own blade style road bike.
Basically shaping polystyrene to form all the main sections, top tube chain stays etc then wraping in carbon fibre he had applied the resin to. He seemed to get good results with the vac bag but i would imagine you get a much smoother finish using negative molds and the whole shape can be done in one shot (well two with the left and right side)
oldschoolace
Team Moderator
Double Flip Whip
Bodger
October 24, 2013, 09:40 PM »
Anyone else want to chime in? Could really do with some experienced insights before i take on this project
Adiers
Curb Endo
October 24, 2013, 11:09 PM »
Hi I work at Redbull racing and I've worked with pre preg carbon for 22 years! Pm me with more details and may be we can sort something out. I make my own bits for road cars, mainley cosmetic bits
oldschoolace
Team Moderator
Double Flip Whip
Bodger
October 25, 2013, 12:36 PM »
Magic
