975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 01:23 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Will vinegar discolour plastics?
Author Topic: Will vinegar discolour plastics?  (Read 1045 times)
Offline jordanjordan
« on: October 18, 2013, 08:47 PM »
I want to clean seat guts with vinegar but if i submerse the whole seat within vinegar will it not fade the colour of the plastic ? :pilky:
Re: Will vinegar discolour plastics?
« Reply #1 on: October 18, 2013, 09:40 PM »
Dont use vinegar use citric acid and make sure the seat is guts down the the tub so the dissolving rust doesn't stain the plastic  :daumenhoch:
A little tub or two from wilkinsons home brew section should be enough or you can buy it on the bay in bulk
I guess this tub aint too little  :LolLolLolLol:
« Reply #2 on: October 18, 2013, 09:46 PM »
thanks for that but its on the rails as well which are inside behind the plastic so the plastic would have to be in aswell ?
Offline Dannywhac
  • return of the whac
« Reply #3 on: October 18, 2013, 10:00 PM »
What Clint's saying is if you have the seat 'gut's upwards' (ie the seats upside down in the citric bath) that the dissolving rust from the rails will settle on the underside of the placcy seat and stain it. If you pop the seat in right way up, then the rusty cack won't settle on the underside of the seat but on the bottom of whatever container you're using  :daumenhoch:
And deffo use citric acid.
« Reply #4 on: October 18, 2013, 10:15 PM »
Once you've finished your seat take it out and you have a tasty beverage, not many people know but this is how they make Irn Bru
Offline Dannywhac
« Reply #5 on: October 18, 2013, 10:48 PM »
Yep:
The surrounding liquid was made in Scotland from girders  :daumenhoch:
« Reply #6 on: October 19, 2013, 04:51 PM »
Maybe use a sieve to filter out some of the chunks :)
« Reply #7 on: October 19, 2013, 07:56 PM »
Could you oxy bath it to clean the rails or would it not agree with the plastic?  :-\
Offline Bfellows
« Reply #8 on: October 19, 2013, 08:39 PM »
I happen to have a set of dominator seat guts stewing in white vinigar at the moment and so far so good........ Tomorrow I'm going to chuck the seat in half a gallon - I'm not overly worried.  The container and lid in the picture is at least 18 months old and shows no sign of discoloration..... Smells a bit mind  ;D
