975808 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 27, 2024, 02:47 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Effing hub problem
Author Topic: Effing hub problem  (Read 595 times)
Frosty
Effing hub problem
« on: August 09, 2006, 01:39 PM »
I bought these knowing there may be an issue with getting the cluster off!!
Having spent the best of a day trying to release the fugger I'm now worse off as I have dropped the hub and managed to get some damage on the (what was) perfect blue anno :tickedoff:
It's been in mole grips, a vice with cloth and rubber securing and using a long torque wrench the thing still wont move.
Anyone got any tips before I end up having to take an angle grinder to it??
Paul
Offline kdw712
Re: Effing hub problem
« Reply #1 on: August 09, 2006, 01:44 PM »
can you not do a part build to get a rim back on and then
go to a bike shop they will shift it off, no probs
for a couple of quid tops
its def easier with a rim to twist against than just a hub
which look pretty sweet by the way  :daumenhoch:
cheers Kev
Frosty
« Reply #2 on: August 09, 2006, 01:57 PM »
Ordinarily I would have done just that, the problem with the bullseyes is that they are a 3 piece hub, so the chances are that I'll end up just spinning off the none drive side flange >:(
« Reply #3 on: August 09, 2006, 02:00 PM »
undo the bearing case of the freewheel and take all
the cogs off that may be a easier option
then use a hacksaw on the rest to loosen it
Frosty
« Reply #4 on: August 09, 2006, 02:10 PM »
If, to do that I need to knock round an inner ring, then I have tried that but with no luck again. It is an old suntour 7 speed cluster.
Really annoying because they are great hubs and I have already manked up the rear a bit >:(
