975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 11:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Will these work with a redline 400 flight crank (Help needed) please.
Author Topic: Will these work with a redline 400 flight crank (Help needed) please.  (Read 1193 times)
Offline Funkyworm
Any info would be welcome, I keep reading that  the 400 is different but i have a cooke bros spinal that fits exactly but would like a unit that supposed to work together.
I've seen 3 options one of which is advertised as working with all manner of cranks & the guy (coffeemilk) off of ebay swears they work but he's bloody expensive.
http://www.ebay.co.uk/itm/310758199158'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Also seen this :
http://www.ebay.co.uk/itm/Bottom-Bracket-Conversion-Crank-set-3-Piece-Vintage-Old-School-BMX-NOS-YST-Alloy-/221275533674?pt=AU_Sport_Cycling_Parts&hash=item33850cb16a
And this:
http://www.ebay.co.uk/itm/321197013009'ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
Offline john4130
i doubt any of them will fit, i had the same problem a few years ago trying to get an axle for my 400s. i bought a square taper axle like the ones above and it was a little bit small and the cranks wouldn't tighten up, i ended up using a shim made from a coke can which worked until i eventually bought an original axle and bearings from here. i think the diamond back harry leary cranks are the same.
Offline sawzall
your'e right john,the flights and the leary's are the same size
they are slightly larger than a standard 3 piece,if there for a show pony just shim them
using a standard 3 piece bb :daumenhoch:
Offline Funkyworm
Cheers chaps, yeah they are for a pony i have one bb but the arms go to far on & theres no room for the dust cap to fit on the arm as the spindle protrudes.... Yeah the sugino 400 the redline & the harry leary cranks all use the same hardware, i think its really the bearings that i need as i have a cook bros spindle that came with it & fits well. The guy had the lot 7 it all came off of a cw cruiser but he left the rest of the bb in the frame as he didnt know how to take it out.   The frame has been sold & i think collected today so im hoping its new owner  can sort me out with the parts... from his frame ???
Offline scoff
How much on eBay?
Try Gumtree it's cheaper
http://www.gumtree.com/p/for-sale/old-school-bmxretro-bmx-usa-bottom-bracket-set-suitable-for-fixie-project-or-old-school-bmx/1033070378
I think you'll have the same problem with the size, a homemade shim would be the answer.
 :chin:
