975801 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 19, 2024, 07:42 PM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  HUB CHOICE? WHATS THE DIFFERENCE ?
Author Topic: HUB CHOICE? WHATS THE DIFFERENCE ?  (Read 369 times)
Offline HARORIDER
« on: October 06, 2013, 12:20 PM »
What's the difference between small and high flange ? (apart from size :LolLolLolLol: ) have they got a purpose ? seen them also mixed small on back/high on front  :-\  I know nothing about wire wheels being a skyway man but just about to restore a pair of pro class for a rider so would be nice to know- cheers guys  :daumenhoch:
Re: HUB CHOICE? WHATS THE DIFFERENCE ?
« Reply #1 on: October 06, 2013, 12:29 PM »
"High-flange" or "large-flange" hubs have a larger flange, usually drilled out for lightness. They transmit torsional forces with less stress to the spokes than small-flange hubs do, but this is not a problem in practice with modern equipment.
High-flange hubs can make a wheel with slightly greater lateral strength than equivalent small-flange hubs, because the spokes create a wider bracing angle to the rim and shorter spokes create greater tension.
This makes them popular with track sprinters, who create greater-than-normal side loads on their wheels.
Offline HARORIDER
« Reply #2 on: October 06, 2013, 12:33 PM »
makes sense  :daumenhoch: :4_17_5:
Offline The Burner King
« Reply #3 on: October 06, 2013, 09:42 PM »
Nice one Stidds, i had wondered why also  :daumenhoch:
Offline insectbones
« Reply #4 on: October 06, 2013, 09:46 PM »
Large flange look so much better too  :daumenhoch:
Offline wilsey72
  • Thats corn that is.
« Reply #5 on: October 06, 2013, 10:59 PM »
Stidds... You're a font of knowledge and have a great way of explaining things. I thank you Sir for learning me lots.  :bow:
GLOUCESTER RIDE 28th July 2018
« Reply #6 on: October 07, 2013, 09:37 PM »
call him Sheldon  ;D
« Reply #7 on: October 07, 2013, 09:45 PM »
they look the same  :LolLolLolLol:
so are both from the same time or did one stay around longer - I thought that large flange came first and then small flange stuck around longer  ???
