975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 09:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Hatta MX10 headset fitting. Advice or experiences?
Author Topic: Hatta MX10 headset fitting. Advice or experiences?  (Read 1061 times)
Deutschmeister
« on: August 08, 2006, 07:32 PM »
Hi, I'm restoring a Birmingham Wheels and tried fitting a new Hatta headset from Alan's today, The old shells knocked out of the frame ok, just a tap either side did it but the new headset looks as though it's flaring the tube when pressing it in. I sanded the inside of the tube with wet & dry paper with oil so its smooth and then started to press the shells in at work and the bottom of the tube started to stretch so I stopped! Anyone else had agro fitting the shells? I work on cars for a living and don't want to give the frame too much grief as it's suvived 24 years so far!
I'll probably take it to someone who knows what they're doing! The frame's about a 1982 so I bought the Hatta MX10 headset, the forks are Tange ARX I think. They're stamped TANGE and have drop outs with four holes in them, 1" thread.
Any help would be appriciated! Just wondering if they're usually this much of a chore!
selfpreservation
Re: Hatta MX10 headset fitting. Advice or experiences?
« Reply #1 on: August 08, 2006, 08:06 PM »
get a piece of threaded bar 12mm is good 2 nuts 2 big washers and 2 blocks of wood with 12mm holes in , put a nut on , then a washer, then a block of wood then the cup , pass it through the headtube of the bike then put the other cup on then block then washer then nut , hey presto you got a cup press tighten the bolts gently untill they are in position , works great for bb as well  :daumenhoch:
« Reply #2 on: August 08, 2006, 08:19 PM »
if the cups are flaring the headtube noticeably then stop there
either find the right size headset, use the old cups, or machine the new.
even though all old bmx frames are 1" forks, there is sometimes a fraction difference in the headtube size. often youll get a frame where the cups feel slack. i have a frame that i just cant seem to knock any cups into - too tight :(
Deutschmeister
« Reply #3 on: August 08, 2006, 08:32 PM »
Cheers, I reckon I'll take the frame into the local shop tomorrow and get him to look at it, the bloke in there's into old skool bikes. I reckon it'll need machining down though :-\ Just didn't want to see the frame split. Thanks.
Jazzchimp
« Reply #4 on: August 08, 2006, 08:37 PM »
Sounds like it's tooo big!
I have had to grind some headsets down. Best to get a micrometer on it to measure the difference.
« Reply #5 on: August 08, 2006, 08:41 PM »
machine the cups not the frame though!
Offline Steve P
« Reply #6 on: August 08, 2006, 08:47 PM »
Do the cups "tip" as you press them into the frame as this can cause the head tube to flare
If so . . . grind or file the sharp tapered leading edge to help press each cup into the frame squarely  :daumenhoch:
Deutschmeister
« Reply #7 on: August 09, 2006, 06:04 PM »
Cheers for all the replies :daumenhoch: I got them in in the end. I measured the old shells with a micrometer and taped the new shells to the chuck of my drill and held sandpaper on them until they came down to the right size ;D went in fine.
Offline Rombloke
  • do one
« Reply #8 on: August 09, 2006, 08:18 PM »
great big fook off hammer
Dave
haro, how do you do
« Reply #9 on: August 09, 2006, 08:28 PM »
Dave
Dave's Toolbox...
Little Hammer
Big Hammer
Fook Off Hammer
