975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 29, 2024, 05:13 AM
RADBMX.CO.UK  |  Old School BMX 1980 - 1988  |  Old School Freestyle (frame stands and kickturns galore!)  |  Gyro help
Author Topic: Gyro help  (Read 1071 times)
rossi
Gyro help
« on: August 08, 2006, 05:07 PM »
hello all out there! after some hel. recently got a Federal T - Nez and have built most of it up - pics soon! 1 thing though - i tried to fit my odyssey gyro from my old bike but it doesn't seem to fit properly and as a result my rear brake is p***. i know my old bike had a regular headset and my T-Nez a hiddenset. i thought about this and bought a GTX-R lite gyro thinking this would fit. just looking at the sizing i am now not so sure. Anybody out got advice or best way to set up? running Evolver brakes front and rear and using twin cable down to brake from Gyro via London Mod. Front brake works like a dream!!
Rossi
Re: Gyro help
« Reply #1 on: August 08, 2006, 05:12 PM »
you did get the tnez with giro tabs didnt ya
if not then no you cant fit it
as theres no were to put the lower cup
rossi
Re: Gyro help
« Reply #2 on: August 08, 2006, 05:14 PM »
yep, got the tabs
Re: Gyro help
« Reply #3 on: August 08, 2006, 05:18 PM »
wot headset you got
as most should work ok and make sure
 there is enuf gap for it to move up and down
and pat at rom uses the new type giro on his fbm
that has a hidden headset
Offline BrianP
Re: Gyro help
« Reply #4 on: August 08, 2006, 05:22 PM »
hi rossi,
is the gtx-r clearing the headtube okay? i'd an issue with a snafu mobeus on a pantera where the inner diameter (ID) of the mobeus (gyro) was too small to clear the headtube and had to do without it. (put on a gtx (the heavier one) instead.
any other gyros u can try? (the gtx-r has a smaller ID than the gtx)
also check the top bearing cover on ur hidden headset. this may be sitting proud of ur headtube, ie bigger diameter, and the gyro's maybe hitting it.
Bp.
rossi
Re: Gyro help
« Reply #5 on: August 09, 2006, 08:08 AM »
Cheers for the help - a weekend of tech  for me!!
