975807 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 03:22 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  grip softening
Author Topic: grip softening  (Read 1154 times)
Offline chubby
  • Needs Pegs
grip softening
« on: September 20, 2013, 09:44 PM »
Hiya fellas, got a pair of mushroom style grips with a frameset recently, they're teal coloured soft rubber in the middle & clear plastic on each end. The clear plastic has hardened & discolored over the years any ideas on how I could soften the ends without fookin them ???
Cheers all
richard. ......
Re: grip softening
« Reply #1 on: September 21, 2013, 10:42 AM »
Go on Richard, i'll play.  :LolLolLolLol:
I doubt you will get rid of the discolouring but autoglym vinyl care is meant to be good as a softener according to Bert  :daumenhoch:
Might be talking bollocks now but i watched a progamme recently where they were using dry cleaning fluid to restore old cinema film tape.
If you can get some it may be worth a stab..... just keep it indoors  :LolLolLolLol:
Offline chubby
  • Needs Pegs
Re: grip softening
« Reply #2 on: September 21, 2013, 10:49 AM »
Thanks clint, pity I've chucked that peroxide away  :LolLolLolLol:
would've taken the colour too I bet....
got some siliconey stuff think I'll bung em in that......
Offline Bfellows
Re: grip softening
« Reply #3 on: September 21, 2013, 03:25 PM »
This stuff....... Used it on a couple of sets of tyre sidewalls and it works a treat without making everything too shiny as long as you buff it up when you're done.  Might be worth a try?
Re: grip softening
« Reply #4 on: September 23, 2013, 09:53 PM »
I've put them in boiling water. Makes them nice and soft. (also done this to remove them off old bars)
Then sprayed Auto Glym on them as said above. Leave it to soak in.  :daumenhoch:
Offline chubby
  • Needs Pegs
Re: grip softening
« Reply #5 on: September 23, 2013, 09:58 PM »
That's spoooooky
im soaking them in boiling water right now  :shocked:
Re: grip softening
« Reply #6 on: September 25, 2013, 06:20 PM »
 :D
That's spoooooky
Re: grip softening
« Reply #7 on: September 25, 2013, 06:25 PM »
if you wait long enough you might get the chance to put it in Ash's sock
The proteins will soften it up a treat
Offline chubby
  • Needs Pegs
Re: grip softening
« Reply #8 on: September 25, 2013, 07:26 PM »
I want to soften them griff not dissolve em  ;D
