976366 Posts in 139000 Topics by 6449 Members - Latest Member: boba fett September 25, 2026, 10:57 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  gt dyno frame(model)
Author Topic: gt dyno frame(model)  (Read 5247 times)
Offline skippyg
« on: September 08, 2013, 05:55 PM »
hi there
 is it possible to identify the model of a gt dyno from just the serial number?
  ive just purchased a 98 chrome gt dyno frame off ebay(not delivered yet) but it has no decals on it
 so I cant tell what model it is
 the serial number is = S8EY04232
 can anybody help or would you need pics if so ill upload some once its delivered
Offline fischflo
Re: gt dyno frame(model)
« Reply #1 on: September 08, 2013, 06:46 PM »
sounds like a Dyno Zone from May 1998
http://bmxmuseum.com/bikes/dyno/41197#.Uiy3Fn-H2jc  ....yours like this one?  ;)
Offline skippyg
« Reply #2 on: September 08, 2013, 06:51 PM »
same shape frame,but like I said its got no decals on it and ive not had it delivered yet,but whats the difference between a 98 dyno zone and a 98 dyno compe?
 coz they both look the same frame to me (as im new to this bmx building)
 many thanks  :daumenhoch:
Offline skippyg
« Reply #3 on: September 08, 2013, 07:19 PM »
ive just got the picture off ebay I hope this helps  "help"
 :daumenhoch: :daumenhoch:
Offline fischflo
« Reply #4 on: September 08, 2013, 08:02 PM »
hard to tell without the stickers; i think the serial gives no clue about model ....?
Not sure if the forks say anything to tell them apart.  "help"
But the Dyno Zone is Hi-Ten, the Compe is Chromoly  ;)
Offline skippyg
« Reply #5 on: September 08, 2013, 08:16 PM »
I read somewhere earlier that the compe had a rear coaster brake tab or something like that "help"
Offline fischflo
« Reply #6 on: September 08, 2013, 08:24 PM »
sounds promising.... however found what seems to be a 98 zone WITH a coaster tab "help"
http://bmxmuseum.com/bikes/dyno/44038#.UizOen-H2jc
Offline skippyg
« Reply #7 on: September 08, 2013, 08:35 PM »
im not that bothered what model it is as I just like the style of the frame ,but it would be nice to know if you know what I mean  :daumenhoch:
Offline fischflo
« Reply #8 on: September 08, 2013, 08:47 PM »
sure, unfortunaltely compes and zones seem notorious for being hard to tell apart.
The difference in steel i mentioned could make for way to discern:
-Hi-ten should be heavier  :crazy2: ...... (however theoretically this should work)
-I think a cromo would have a slightly wider seat tube diameter ....?
-THink a file would slide off cromo. (if there were a spot w/o chrome where you could test & w/o using pressure)
sooorry  :D
 "help"
« Last Edit: September 08, 2013, 08:51 PM by fischflo »
Offline Munnyella
« Reply #9 on: September 08, 2013, 08:54 PM »
Speak to GTnumber1 (steve costa)
he is the authority on anything GT/Dyno.
I would say comp, I have a 99 zone, no tabs, thicker tubes, heavy as fook.
looks like you got the right one!!!
MM
Offline skippyg
« Reply #10 on: September 08, 2013, 10:55 PM »
thanks for all your help guys  :daumenhoch: :daumenhoch:
