975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 21, 2024, 01:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  headset rebuild - loopy ripper
Author Topic: headset rebuild - loopy ripper  (Read 3149 times)
Offline adammannering
« on: September 05, 2013, 05:14 PM »
Evening Peeps
I am struggling to find where this ' extra ' piece goes ?
My headset appears to loosen ( the round bit with grippy edge ) - keeps coming loose.
I am a bit of a novice here, any help appreciated
thanks guys
addy
Wanted any condition pk ripper repop for my daily rider !
Offline That Swan Guy
Re: headset rebuild - loopy ripper
« Reply #1 on: September 05, 2013, 05:16 PM »
that looks like the fork crown!
« Reply #2 on: September 05, 2013, 05:31 PM »
+1 agreed  :)
« Reply #3 on: September 05, 2013, 05:40 PM »
here is another photo.....
so where does it go ?
everything ' seems' to work ok....
however the ' round piece with cerrated edge' seems to come loose...????
« Reply #4 on: September 05, 2013, 05:59 PM »
I would hazard a guess that that crown race should b on the forks and ur bearings look like they r in upside down  :daumenhoch:
Offline Betty
« Reply #5 on: September 05, 2013, 07:28 PM »
That bit in your hand looks like the fork crown race, there may already be one on your forks?
If not it slides over the fork steerer the opposite way up to how you're holding it in the pic, the bearing race faces upwards
The bearings should be fitted with the cages in the cups and the balls (ooh err) facing outwards
If the top nut is tightened all the way down in the first pic you'll need a washer below it to keep the adjuster tight it'll never stay tight if there's a gap
2 minutes turkish...
Offline Dannywhac
  • return of the whac
« Reply #6 on: September 05, 2013, 07:32 PM »
As per above  :daumenhoch:
Here's an exploded view of one (yours probably won't have the 'seal' bit):
« Reply #7 on: September 05, 2013, 07:55 PM »
Nice one everyone
Will invert my balls tomorrow
Superb stuff - cheers
Addy
« Reply #8 on: September 05, 2013, 08:40 PM »
I do have the washer pictured above - but if I remember correctly it sits snug within the cerrated adjustable race part of my headset .  The diameter is smaller and fits on like a glove.
Surely because its ' inside ' this piece - it's not doing anything ?
Cant take any pics - as I'm at work unfortunately
Cheers addy
Offline Dannywhac
« Reply #9 on: September 05, 2013, 08:47 PM »
Beartrap headset then? Yeah the toothed washer slots down on top into a recess on the adjustable race. What it does is stop your headset loosening over time.
« Reply #10 on: September 05, 2013, 09:17 PM »
 Not too sure what it is bought at MK13.
But you've described it spot on Dannywhac....
Ok so why is the adjustable race still loose ?
Should I buy an extra washer, larger in diameter to sit on top of this - to stop it moving ?
Tad confused
« Reply #11 on: September 05, 2013, 09:20 PM »
It doesn't look like a bear trap 2. If it is you have 2 washers missing, one with the all important teeth that lock into the upper adjustable race. You're best off taking it all off and take a pic of all the pieces plus the bottom of your fork shaft and we'll talk you through it :daumenhoch:
« Reply #12 on: September 05, 2013, 09:29 PM »
Cheers thatswanguy
Will take it apart tomorrow morning.
Thanks all
Addy
« Reply #13 on: September 06, 2013, 08:35 AM »
I must of bought this off ebay - and found a picture !
looks like this piece sits on top of adjustable race ?
will give it a go - and check all the balls are up the right way etc....
« Reply #14 on: September 06, 2013, 08:56 AM »
that bit in your hand on the first picture is a fork crown race.
looks nothing like a locking nut to me  :-\
« Reply #15 on: September 06, 2013, 09:46 AM »
i know what your saying pickle and tried that - but as you can see from photos - it just didnt ' sit ' at all right and was clunky.
i have since tried it the way as in diagram and all is absolutely fine, ill post some piccies.
showing clunkiness
showing forks as they are
with bearings on
« Reply #16 on: September 06, 2013, 09:51 AM »
this is what it is set up at the moment - and seems to be all snug as a bug.
this piece does look like the crown race - but it seems to be doing the trick as the washer ?
OR AM I JUST A TOTAL FOOL  ;D
please let me know your thoughts / feelings - I am off to rom skatepark on this tomorrow >>>!!!   ???   !!!
Offline insectbones
« Reply #17 on: September 06, 2013, 09:52 AM »
Right fella...take it all apart and have a look at your forks to start with. They should look like this....
That spare bit in your hands should be on your forks, as in my photo, is there one on yours?
Offline insectbones
« Reply #18 on: September 06, 2013, 09:55 AM »
Ignore my reply, i see your crown is in place  :daumenhoch:
« Reply #19 on: September 06, 2013, 09:58 AM »
yes its there deffo
« Reply #20 on: September 06, 2013, 10:01 AM »
It shouldn't be on there it is a fork crown. All headsets come with one and your forks may already have one fitted, therefore it is a spare part.
« Reply #21 on: September 06, 2013, 10:03 AM »
I think - there was a piece missing....when it was sent to me  ?
but this ' remedy ' seems to be working a treat - with the adjustable race not becoming loose as before....
....and if i dont get out riding this weekend - i will cry.
i know it doesnt look right - but it will get me out on the road / skatepark and enjoying the bike - until i buy a new one.......
waddya reckon ?
« Last Edit: September 06, 2013, 10:05 AM by adammannering »
Offline insectbones
« Reply #22 on: September 06, 2013, 10:04 AM »
+1, stick it in a drawer, you don't need it.
« Reply #23 on: September 06, 2013, 10:06 AM »
waddya reckon ?
Fair point. If it works put a stem pad over it  :LolLolLolLol:
« Reply #24 on: September 06, 2013, 10:07 AM »
thanks for all your invaluable help fellas !
i am still learning all this - BITD - My pops done everything for me.....
ddaaaaadddddd can you fix my biiikkkeeee ! ! ! ! ! ! etc etc......
loving the learning.........but really just wanna ride this weekend.....
