975805 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 05:03 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  rear brake problem with my curtis freestyler
Author Topic: rear brake problem with my curtis freestyler  (Read 1041 times)
Offline curtis1984
« on: August 29, 2013, 08:28 AM »
morning chaps,
Im restoring my freestyler and am having major issues fitting my rear brake (sounds simple!)
Im trying to fit MX901's.
first issue: trying to fit them normal way round, the rear standing loop interferes with the adjuster so I thought i'll reverse the brake around and put in on the underside where the chain I now rubbing against the arm of the brake.
There is a serious lack of room to adjust anything here!
I am thinking I may need to get a rear MX890?
any advice would be appreciated
Offline scoff
Re: rear brake problem with my curtis freestyler
« Reply #1 on: August 29, 2013, 09:12 AM »
Any chance of a pic?
I've just had a similiar problem on my son's Blank, there was a lot of head scratching, but I got there in the end.
Offline dannyrobo
« Reply #2 on: August 30, 2013, 01:04 AM »
hi,901s do fit but they are tight, here`s a pic its not the best angle but i hope it helps  :daumenhoch:
Offline Funkyworm
« Reply #3 on: August 30, 2013, 07:14 AM »
I think you need mx 1000's mate or 880's as the adjusters  don't stick up so high.
« Reply #4 on: August 30, 2013, 09:38 AM »
yeah an 880 would fit nicely, or a Nippon  ???
Offline scoff
« Reply #5 on: August 30, 2013, 10:14 AM »
I was going to suggest an 880, but too late.
Offline bodamus
« Reply #6 on: August 30, 2013, 11:41 AM »
Always ran an MX900 on mine :daumenhoch:
rodriguez
« Reply #7 on: August 30, 2013, 12:19 PM »
DC890, MX900, MX901 all the same reach IIRC
Offline curtis1984
« Reply #8 on: September 01, 2013, 07:28 PM »
Thanks for all the replys chaps,
Ive taken a look at dannys pic above and refitted the 901, its mighty tight, ive put on some clear brake pads to reduce the spacing a bit, did want to keep black ones on there though, will post pics once my layback arrives
thanks again
steve
