975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 01:18 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DB Senior Pro - HLT ?
Author Topic: DB Senior Pro - HLT ?  (Read 992 times)
Offline Peter J
  • I have issues
« on: August 28, 2013, 09:47 PM »
Is the DB Senior Pro F&F the same geometry as the HLT F&F ?
Re: DB Senior Pro - HLT ?
« Reply #1 on: August 29, 2013, 07:58 AM »
yep,  exactly the same frame and forks....  ;)
« Reply #2 on: August 29, 2013, 01:42 PM »
Correct. Can't even tell by the serial number if both frames were raw despite the senior pro coming out in late 81 and the HLT in around March 82.
Offline sparky
« Reply #3 on: August 29, 2013, 10:15 PM »
Nearly right, 1st gen Senior Pro was released in Spring '81.  :daumenhoch:
The frame then was updated with a rear leverage change which was basically the rear dropouts angle, which slightly raised the ride height in early '82.  :)
Offline Pooch
  • funny you should say that..
« Reply #4 on: August 29, 2013, 10:38 PM »
  :knuppel2: I was just about to say that..
Griff loves BUM..
