975755
TattooedYorkie
September 22, 2024, 01:36 PM
What bottom bracket kit for flight crank?
Topic: What bottom bracket kit for flight crank? (Read 509 times)
Bfellows
Flip-Whip
August 21, 2013, 10:11 PM »
I have a flight crank heading my way, do I need a specific bottom bracket kit?
Ta
Bert
oldtired
540 Air
Dirty Old Man
Re: What bottom bracket kit for flight crank?
August 21, 2013, 10:21 PM »
which era flight crank, and what size is the bb on the frame ?
Bfellows
Flip-Whip
August 21, 2013, 10:39 PM »
401 full wrap flights with standard 51mm (?) US style BB.
oldtired
540 Air
Dirty Old Man
August 21, 2013, 10:56 PM »
from that info bb will be standard U.S one....... if the spindle is an un threaded one...
however some redlines had different spindles , depending on the what years they're from, which may affect the bb type you need
check out this thread , covers a lot of redline gens ,and the bb that go with em, if you're unsure when it lands post up a pic , you'll get a definite answer from someone then
http://bmxmuseum.com/forums/viewtopic.php?id=13478&p=1
Last Edit: August 21, 2013, 11:02 PM by oldtired
Bfellows
Flip-Whip
August 22, 2013, 07:37 PM »
Spot on! Thank you!
