975755
TattooedYorkie
September 21, 2024, 12:40 PM
Freewheel removal
Topic: Freewheel removal (Read 672 times)
scoff
Curb Endo
Freewheel removal
August 12, 2013, 07:20 AM »
Without a 2 pin tool, is there any easy way of removing this freewheel?
Any tips would be much appreciated.
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Re: Freewheel removal
August 12, 2013, 07:24 AM »
big flat screwdriver and hammer
GavinDavis
BMX Nerd
August 12, 2013, 07:35 AM »
Remove the axle, put a flat length of steel in a vice so that it locates in both recesses and turn it anticlockwise. It will probably be a bit of a bugger to remove so a bit of downward pressure will be necessary
That Swan Guy
Team Moderator
Double Flip Whip
August 12, 2013, 07:37 AM »
Hammer and 6" nail
scoff
Curb Endo
August 12, 2013, 09:14 AM »
Wow, fast responses.
I'll try them all, if I've any working fingers after, I'll type which method worked..?
oldschoolace
Team Moderator
Double Flip Whip
Bodger
August 12, 2013, 11:27 AM »
Dont try and turn it by the two holes, all you will do is take the freewheel apart and have bearing everywhere! As Gav says its the two flat recesses you need to turn
Dannywhac
BMX Nerd
return of the whac
August 12, 2013, 11:38 AM »
x2 on what Clint said
If all else fails and you can't gerrit off and you don't mind sacrificing the freewheel, take the freewheel apart using them two small round holes, remove the toothed wheel and take out the pawls on the freewheel. Where the pawls were are nice big recesses that you can get you screw-driver in and tw@t the bugger off
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
Freewheel removal
