975797
Bmxflex
November 15, 2024, 08:40 AM
BMX General
BMX Chat
profile crank removal/ powerlite profiles same i guess later type
Topic: profile crank removal/ powerlite profiles same i guess later type (Read 506 times)
pkripster
Rockwalk
August 05, 2013, 01:12 AM »
im using profile removal tool the bolt seems hard to turn anyone had experience with these lmk its the big bolt tool wiv spacer
Last Edit: August 05, 2013, 01:15 AM by pkripster
Dannywhac
BMX Nerd
return of the whac
Re: profile crank removal/ powerlite profiles same i guess later type
August 05, 2013, 09:04 AM »
If you're removing the cranks you don't use the spacer on the removal tool, just screw in the centre threaded bit and welly the end to knock the arms off the axle.
You only use the spacer part if you're putting the cranks on.
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
PK.RIPPER
Curb Endo
August 13, 2013, 04:08 PM »
I just hit the arms off with a rubber mallet, but always put a little bit of engine oil on the axle splines before putting the arm back on so next time it's a piece of cake.
BMX General
BMX Chat
