975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 07:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Cruiser BB question
Author Topic: Cruiser BB question  (Read 636 times)
FuNMoNsTeR
Cruiser BB question
« on: August 04, 2006, 02:31 PM »
I have fitted a Sugino 1 piece crank and BB from a silver streak to my Torker cruiser... The bearings and bearing cages look in good shape but there is resistance when i pedal backward and i have to run the assembly 'loose' for it to move freely. Are cruiser BB made to take a different size bearing in the Bottom Bracket?
Re: Cruiser BB question
« Reply #1 on: August 04, 2006, 02:38 PM »
Have you checked the chain tension? and that the chain ring and sprocket are paralel?
Offline HUTCHMAN
« Reply #2 on: August 04, 2006, 04:49 PM »
also is the resistance constant or loose then tight?if loose then tight,then your chainring probably isn't running concentric,it'll need centering.
Bren Gunn
« Reply #3 on: August 04, 2006, 07:15 PM »
Have you got the bearings in the right way around?
Offline Waxintaxin
« Reply #4 on: August 04, 2006, 07:28 PM »
concentric
nice word
Rich
Offline Dingobmxer
« Reply #5 on: August 04, 2006, 09:54 PM »
did you check the chainline Andy??
 :) DINGO :)
bof
« Reply #6 on: August 04, 2006, 11:38 PM »
If I left the cups in the bottom bracket (which I think I did)I suggest you take them out and fit different ones they where from some weird BB that required matching bits, if you compare your diamond back cups closely they will look different.
The stem was made by a bloke who was part of the Ashton bikes team (ashton under-lyne, Manchester) There where quite a few of them knocking about round here.
The frame is I am almost sure a 340x it came out at the same time as the  oval gusset 20 inch torker which should make it easier to put a year to it.
