975806
V6 DOW
November 25, 2024, 12:33 PM
Bearings to fit a 20mm axel
Topic: Bearings to fit a 20mm axel (Read 606 times)
Stillriding
Riding with Stabilisers
July 24, 2013, 12:08 PM »
Hi lads can any one help me out with a search for a set of bearings that fit a 20mm BB axel it seems they exist !!!!!!
oldschoolace
Team Moderator
Double Flip Whip
Bodger
Re: Bearings to fit a 20mm axel
July 24, 2013, 05:33 PM »
What size is your bb?
Dark Diggler
Berm Worm
July 24, 2013, 05:36 PM »
Maybe these, ring em though, nice people
http://www.customriders.com/prodshow.asp?prodid=7255&cat=8&parent=1001&sid=3
Stillriding
July 24, 2013, 11:18 PM »
Thanks lads I've found some from a bearing shop they are to go in a us bb ,the bearing race are an odd size on 20mm axles but after a lot of searching I've got some if anyone else has the same problem let me know and I'll point you in the right direction
Munnyella
Look Back
July 25, 2013, 09:04 AM »
I had a set of federal profile type cranks that were on 20mm, lots of more modern Haro completes are 20mm too, they are easily available from online bike stores or from a bearing centre in most towns.
MM
