975809 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 28, 2024, 12:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Help fitting 3pc crank
Author Topic: Help fitting 3pc crank  (Read 990 times)
Offline brettnai
« on: July 13, 2013, 01:01 PM »
Just bought a  United Nash NS crank for my bike. I've never fitted once from scratch.
Can someone tell me which order I should do things?
I have a sprocket and top hat shim washer thingy. Should the sprocket go on first and then the shim or vice versa?
I'm guessing the sprocket so it's flush against the crack arm with no gap
Is that right?
Offline Jon The Bassist
Re: Help fitting 3pc crank
« Reply #1 on: July 13, 2013, 01:17 PM »
Usually, yes. There are loads of videos on youtube for stuff like this that will show you how better than i could clumsily type :daumenhoch:
Offline Dannywhac
  • return of the whac
« Reply #2 on: July 13, 2013, 01:20 PM »
Yep - sprocket on first, hand tighten bolt so there's still a bit of movement. Then pop on the top hat washer, pop your axle through as a guide so the sprocket hole and crank arm hole line up proper and tighten the sprocket bolt.
Offline brettnai
« Reply #3 on: July 13, 2013, 01:35 PM »
sweet, all done! thanks
Offline Devilock
« Reply #4 on: July 13, 2013, 01:55 PM »
You're wrong & you're a grotesquely ugly freak.
Offline Dannywhac
« Reply #5 on: July 13, 2013, 02:02 PM »
Thanks.
