975884 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 18, 2025, 12:35 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  spoke advice
Author Topic: spoke advice  (Read 1164 times)
winnit93
spoke advice
« on: August 01, 2006, 10:25 PM »
ive got these gt hubs that im useing on my next build
the rims im useing are nos ukai 1 1/8.
what size spokes do i need.
winnit93
Re: spoke advice
« Reply #1 on: August 01, 2006, 10:46 PM »
I know the ERD (effective rim diameter) . . . I need the following ??
  • Hub flange diameters
  • Hub centre to flange measurements on each hub (centre to R/H flange and centre to L/H flange)
Steve  :daumenhoch:
right steve
its the hub centre to flange measurement that confuses me,am i right in thinkin i measure frome the gt sticker in the middle of the hub to the edge of the flange.
thanks
scotty
Offline Steve P
Re: spoke advice
« Reply #2 on: August 01, 2006, 10:51 PM »
Cheers . . . not sure where my 1st reply disappeared too  ???
Yeah . . . that's it . . . measure the distance from the centre of the hub across to the centre of each hub flange
Are they 36 hole Ukai you're using too
Steve
winnit93
Re: spoke advice
« Reply #3 on: August 01, 2006, 11:09 PM »
ye 36 hole
front flange diameter 480mm
rear flange diameter 550mm
from centre to flange front hub 350mm
from centre to flange rear hub 330mm
hope this all makes sence
Offline Steve P
Re: spoke advice
« Reply #4 on: August 01, 2006, 11:14 PM »
ye 36 hole
WOW . . . them hubs are huge Scott  ;D
Should be:
front flange diameter 48mm
rear flange diameter 55mm
from centre to flange front hub 35mm
from centre to flange rear hub 33mm
Two secs . . . I'll check it out for you  :daumenhoch:
winnit93
Re: spoke advice
« Reply #5 on: August 01, 2006, 11:17 PM »
i wouldnt mind but i work with measurements :LolLolLolLol:
i recon im tired :LolLolLolLol:
Offline Steve P
Re: spoke advice
« Reply #6 on: August 01, 2006, 11:51 PM »
With your hub measurements . . . using long nipples
Cross 3 pattern . . . 210mm spokes
Cross 4 pattern . . . 218mm spokes (recommended)
Let me know if you need any more help
Steve  :daumenhoch:
Re: spoke advice
« Reply #7 on: August 02, 2006, 09:37 AM »
tuffs.
Re: spoke advice
« Reply #8 on: August 02, 2006, 11:24 AM »
