975811 Posts in 138943 Topics by 6371 Members - Latest Member: Robertflamn November 30, 2024, 12:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  stuck stem bolt
Author Topic: stuck stem bolt  (Read 1902 times)
Offline gary4130
stuck stem bolt
« on: May 30, 2013, 09:36 PM »
got a rounded off stem bolt ,does anybody have any advice for getting it out?
think somebody has tried to get it out before as its been drilled a few mm in -see third pick
Re: stuck stem bolt
« Reply #1 on: May 30, 2013, 10:12 PM »
It's under pressure at the mo and will be a bugger to move  ::)
One way I know is to cut the bolt in the middle and then you might be able to shift each half better when the pressure is off  ;)
wait to see what others say first  ;)
Offline GavinDavis
Re: stuck stem bolt
« Reply #3 on: May 30, 2013, 10:22 PM »
You would have to be careful but you could always try and drill the head of the bolt off the shoulder of the thread?
Or maybe put a crappy allen key into the head and carefully try and get a couple of tack welds on it.....then use a small spanner/adjustable etc?
Re: stuck stem bolt
« Reply #4 on: May 30, 2013, 10:23 PM »
yer not always easy - that why I said to wait to see if any one else has a better Idea  :crazy2:
but the bolt at the mo is under pressure, so unless a good grip it will not turn  :tickedoff:
Re: stuck stem bolt
« Reply #5 on: May 30, 2013, 10:23 PM »
Put the other bolt back in and tighten it up slightly tighter than the stuck bolt. Assuming you have soaked it in wd40 etc then try and tap a flat screwdriver into the bolt head whilst applying a slight anticlockwise twist to the screwdriver.
Failing that you could try one of those screw extractor gismo's  :daumenhoch:
Offline bobbbbsy
Re: stuck stem bolt
« Reply #6 on: May 30, 2013, 10:24 PM »
cut a screwy groove in both ends then chop in the gap . try and unscrew ? what tools you got ? or take it somewhere with a good pillar drill
Offline kev-s
Re: stuck stem bolt
« Reply #7 on: May 30, 2013, 11:21 PM »
soak the bolt in wd40 then get a allen key bit or torx bit (socket set or screwdriver type ones) that is slightly bigger than the bolt and hammer it in and then unscrew it with the socket bar or screwdriver :daumenhoch:
Offline Betty
Re: stuck stem bolt
« Reply #8 on: May 30, 2013, 11:55 PM »
This
2 minutes turkish...
Offline jT Racing
  • i like bikes. :/
Re: stuck stem bolt
« Reply #10 on: June 01, 2013, 10:34 AM »
You can buy a tool for this, they sell them in the local Asian discount store for £3-£4
Saves a lot of fecking about.
ding dong
Offline jT Racing
  • i like bikes. :/
Re: stuck stem bolt
« Reply #11 on: June 01, 2013, 10:36 AM »
ding dong
Offline gary4130
Re: stuck stem bolt
« Reply #12 on: June 01, 2013, 05:53 PM »
Cheers for the help guys all sorted now. ;)
Did it by tightening the ok bolt +then get a wide screwdriver bit in on a socket set +out I came  :shocked:
Will get one of those bits for next time though :LolLolLolLol:
