975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  rear axle removal
Author Topic: rear axle removal  (Read 544 times)
Pottinger
rear axle removal
« on: May 29, 2013, 09:03 AM »
i presume im correct in thinking i have to remove the freewheel (with the correct tool  ::) ) in order to
get the rear axle out ??
or do you undo the opposite side to the freewheel and slide it out ? prob a silly question to most but if ya dont know ya dont know  :'(
cheers
potts
Re: rear axle removal
« Reply #1 on: May 29, 2013, 09:05 AM »
You can do it either way actually, but it is always easier with the freewheel off.
Offline Munnyella
« Reply #2 on: May 29, 2013, 08:08 PM »
Depends on hub, most old schoolers are, as Stidds says, but I have some mid sealed hubs that are only do-able non drive side unless the freewheel is off, it is a 14mm axle, small thread freewheel though.
Pics, or more info may help with a definative answer!!
MM
