975804 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 23, 2024, 02:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  gyro with old style levers
Author Topic: gyro with old style levers  (Read 560 times)
simondo-el-lupo
« on: July 31, 2006, 06:27 PM »
Help me, I've got some mx1000 copy  levers and calipers can i use these with a gyro set up when i got the upper cable it only will connect to the lever by the screw in type doofer ::)(technical term I believe) i dont know what its called but it holds the cable in the lever, and how do i fit the front cable on side pull brakes.Can you help or am I way wide of the mark and should i just bin the gyro. Cheers
