975755
TattooedYorkie
September 22, 2024, 02:29 PM
seat dying
Topic: seat dying (Read 980 times)
adeshere
seat dying
July 30, 2006, 10:22 PM »
Ok, so when dying a seta, will the gold lettering be effected ?
Rombloke
Team Owner
My life is Radbmx
do one
Re: seat dying
July 30, 2006, 10:26 PM »
no.....
easy
Dave
haro, how do you do
adeshere
Re: seat dying
July 30, 2006, 10:32 PM »
So when i dye my white seat and the gold lettering goes a funny colour, i'll send it round to you with a gold pen ..
cheers
Stodgy
BMX Overlord
Re: seat dying
July 31, 2006, 05:24 PM »
Might make it flake a little, but nothing too disturbing!
www.radbmxshop.co.uk
lazychubs
Founding Fathers
BMX Nerd
Re: seat dying
July 31, 2006, 05:40 PM »
that wouldnt be the white seat i lost out to you on ebay was it lol
not that im angry or anything
jT Racing
BMX Overlord
i like bikes. :/
Re: seat dying
July 31, 2006, 05:41 PM »
when it's fully dead we'll have a wip round and get it a proper funeral.
ding dong
adeshere
Re: seat dying
July 31, 2006, 10:14 PM »
If its a white Dominator Pro, then yes
Not sure if to keep it white or dye it red to go on my TA, which is a red and white build
adeshere
Re: seat dying
August 02, 2006, 09:22 PM »
So, i need to use Dylon dye to do the seat.
Do i need to use
COLD WATER DYE
or
MULTI-PURPOSE DYE
Rombloke
Team Owner
My life is Radbmx
do one
Re: seat dying
August 02, 2006, 10:32 PM »
multi purpose....and shit loads of salt as a fixing agent.....cue graham.....wheres the pic
Dave
haro, how do you do
adeshere
Re: seat dying
August 03, 2006, 12:02 PM »
Normal salt you put on your chips, or special salt ?
Waxintaxin
Team Owner
Cherry Picker
Re: seat dying
August 03, 2006, 12:07 PM »
cheap table salt will do mate
a lot of salt , i used a kilo for a seat
Sanmarcopizza
Re: seat dying
Reply #11 on:
August 03, 2006, 12:48 PM »
And you need hot water. I have done loads of seats and had no probs. Bring huge pan of water to boiling temperature, but not bubbling. Add the salt ( I normally do 750gms) and add the seat for 5 minutes. I then add 2 tubbs of Dylon M.P. Dye and leave to simmer for 45 mins. You need to ensure any contact point in the pan take colour, so shift the seats position. Avoid touching the gold writing at all costs when it's hot as it will damage it. When finished, run the seat under a cold tap to set the writing. Seat is best handled by rails and a pair of pliars or similar.
adeshere
Re: seat dying
Reply #12 on:
August 03, 2006, 01:49 PM »
Thanks.
That is a brillinat description.
do you put the seat in the pan with the bars pointing toward you, or touching the bottom of the pan ?
Sanmarcopizza
Re: seat dying
Reply #13 on:
August 03, 2006, 02:07 PM »
Depends on your pan. I used to have to sit mine diagonally to get it in the pan, so tended to put the rear of the seat at the bottom, rail side down. My only contact points tended to be the underside front edge and maybe an edge either side on the underside rear. I used to just move it around a few times.
adeshere
Re: seat dying
Reply #14 on:
August 03, 2006, 02:28 PM »
I will give it a go
BUT
How do i convince the misses that i should use her shiny pan !!!
Sanmarcopizza
Re: seat dying
Reply #15 on:
August 03, 2006, 02:30 PM »
By doing it while she is out and cleaning it afterwards. As a word of warning, the dye is a very fine powder. Be careful when opening !
sawzall
540 Air
Re: seat dying
Reply #16 on:
August 03, 2006, 07:16 PM »
i got a stainless steel bowl from a £1 shop,still made a fookin mess of the cooker,crystalised salt and dye everywhere
Waxintaxin
Team Owner
Cherry Picker
Re: seat dying
Reply #17 on:
August 04, 2006, 12:58 PM »
I used a normal builders bucket , added salt and seat and dye , then poured a few kettles of boiling water over it to cover , left for 30 mins stirred another 30 mins and done
no mess , no moans cos you destroyed the cooker / kitchen/house
adeshere
Re: seat dying
Reply #18 on:
August 04, 2006, 02:47 PM »
Ah, maybe i should try the bucket method, otherwise i'll end up having to clean the whole kitchen !!
seat dying
