Sure there not removable mounts for the brake ?
It's alright that for the money Salt is wethepeoples own parts brandShame about the lugs, have they been chopped off or are they removable screw in ones that are just missing?
You can buy removable cable guides,you`ll need to grind down the remnants of the originals and drill/tap the frame.Perhaps the lugs can be modified to take a set of removable lugs (also available to buy).
just the same size as the bits after the screw in removable legs have been unscrewed. go see if its got threaded holes wtp is salt and vice versa but salt also supply other firmsdos nt look like a piece of crap to me. you sure you are not looking at your burner by mistake?
It's defo subrosa dos it say pandora on the bottom bracket , the SDT stands for signal down tube, I think they came as frame only, forks were purchase seperately , £100 not bad if ya can sort the brake issueRattle can the bars and it will look half decent
deffo removable brake lugs. should be able to pick a set of those up okay
Looks more like a 2008? Subrosa Armada to me, look at the brake bridge on this one for example -> http://bmxmuseum.com/bikes/subrosa/27423 edit: or f.ex. also ->http://bmxmuseum.com/bikes/subrosa/53579 Looks like your frame ..... hey wait, the area around the bb/chainstays on both these bikes looks different from yours... Same thing with the Letum (2010) model f.ex ->http://bmxmuseum.com/bikes/subrosa/33689....or also with the Novus 2009 model ->http://bmxmuseum.com/bikes/subrosa/59450Perhaps things are different with a Salvador 2008 ----cant't see the relevant detail here unfortunaltely---- -> http://bmxmuseum.com/bikes/subrosa/66810Same applies here Malum 2008 -> http://bmxmuseum.com/bikes/subrosa/9710
well yeah, perhaps a pandora older than 2008 or a another model(/older than that)
Should already have a threaded hole for the cable hanger as well.
Quote from: fischflo on April 29, 2013, 12:54 PMwell yeah, perhaps a pandora older than 2008 or a another model(/older than that) The 2008 cruiser has the same design behind the BB Im thinking it's possibly a 2007 model
Quote from: Funkyworm on April 29, 2013, 01:00 PMQuote from: fischflo on April 29, 2013, 12:54 PMwell yeah, perhaps a pandora older than 2008 or a another model(/older than that) The 2008 cruiser has the same design behind the BB Im thinking it's possibly a 2007 model THink i found a 2010 Letum with your design in the bb area ... ->http://bikemarkt.mtb-news.de/article/30486-subrosa-bmx-subrosa-letum-dirt
