975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 05:31 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  A nice little mod for my new build (pic heavy)
Author Topic: A nice little mod for my new build (pic heavy)  (Read 3017 times)
« on: April 20, 2013, 01:49 PM »
Starting to gather a few gems for my latest build, a Starway freemaster pro  :smitten:
I always like to try new things with my builds and after seeing a few Woody Itson trickstar roller cam brake builds on the museum i decided to have a go myself.... with an Oddy pitbull  :D
The Woody's for reference
So the first issue is mounting the brake itself, as the pitbull is mounted with a traditional bolt the shaft inside the fork would have to straddle the bolt with enough clearance not to bind when in use.
In order to keep the shaft plumb and running smooth i bought a linear bearing. The shaft is 12mm diameter and the bearing is 12mm internaly and 21mm externally. The forks were 21mm at the top and tapered to just under 20mm where the break is mounted for some reason. Luckily i had already bought a beefy drill bit for another stem little project  ;) so it was staightforward to bore out the tube to the depth i needed for the bearing
Next i made a little bracket out of a 50mm x 50mm piece of 2mm steel plate. Cut like a capital letter V and bent in the vice to mirror the pitbull wedge shape.
The type of bearing i used is an extra long one, 57mm, the standard ones are 32mm i think but i wanted the extra length to help keep everything running smooth
The shaft offered up to the plate and ground to the right angle
I made a little jig to keep everything square whle the JB Weld went off ( Once i knew everything lined up with the brake the joint was cleaned up and welded properly)
Once the shaft was cut to length i welded a small penny washer to the top to act as a stop for the pear end of a cable ( the pear fits nicely inside the shaft )
The final result looks alot cleaner without the cable and horrid plastic cable hanger that is stock with the pitbull
The cable will run through a barrel end mounted in the pots bolt of a freestyle stem and a modified Oddysey Knarp will attach the cable to the brake lever.
Just need to strip the pitbull now for a fresh coat of white paint and give the little pulley wheels a spot of grease  :daumenhoch:
Thanks for looking guys, Clint
Offline GavinDavis
Re: A nice little mod for my new build (pic heavy)
« Reply #1 on: April 20, 2013, 02:06 PM »
Fair play Clint! Another top job mate! Nice work  :daumenhoch:
« Reply #2 on: April 20, 2013, 02:40 PM »
The ingenuity of some of the people on here never cease to amaze me.
Very clever indeed Clint.  :daumenhoch:
Adam
« Reply #3 on: April 20, 2013, 03:08 PM »
top skills...nice1 :daumenhoch:
deeman
« Reply #4 on: April 20, 2013, 04:42 PM »
Top work Clint,always outside the box but brilliant! :daumenhoch:
« Reply #5 on: April 20, 2013, 09:15 PM »
Cheers guys, pretty chuffed with the results  :)
chubby
« Reply #6 on: April 21, 2013, 12:16 PM »
 :shocked: that's boggled my mind clint.......
Offline Discostu
  • Two's Company
« Reply #7 on: April 21, 2013, 06:34 PM »
I'm currently doing this on my trick star. It's a slightly different design to yours but the principle is the same. You have done a nice job.  :4_17_5:
Offline Darren KAP
« Reply #8 on: April 21, 2013, 07:19 PM »
  sweet job bud  :4_17_5:
« Reply #9 on: April 21, 2013, 07:44 PM »
Skills!  :4_17_5:
« Reply #10 on: April 21, 2013, 07:49 PM »
Superb fella  :coolsmiley:
« Reply #11 on: April 21, 2013, 08:35 PM »
Are you thinking of bolting your bracket to the back of the wedge by any chance? The holes would lend themselves to this.
I decided against it as i think it would give you less clearance on the caliper frame and less travel for the pads. Adjusted properly though it should be fine  :daumenhoch:
Offline Taipan
« Reply #12 on: April 21, 2013, 09:00 PM »
Skill's  :4_17_5: :daumenhoch:
Offline Discostu
  • Two's Company
« Reply #13 on: April 21, 2013, 09:13 PM »
my wedge and the lifting bar inside the forks are going to be one piece. just like the original hutch prototype. im also using the suntour roller cam brake with linear sprigs. it will look the same as the hutch picture you have posted above. :)
« Reply #14 on: April 21, 2013, 09:14 PM »
Sounds cool, looking forward to seeing it  :daumenhoch:
« Reply #15 on: April 22, 2013, 09:44 AM »
If I use it 'sprig' ... its always linear  :daumenhoch:
Offline not johndub71
« Reply #16 on: April 22, 2013, 10:13 AM »
Excellent engineering!
Facebook/Fr35Hair
« Reply #17 on: April 25, 2013, 08:51 PM »
Had a bit of time today for some fine tuning  :)
Drilled and taped a couple of holes in the plate for some adjusting bolts
And a quick vid of the thing in action  :coolsmiley:
Click on the pic  :D
« Last Edit: April 25, 2013, 08:54 PM by oldschoolace »
Offline martin46
« Reply #18 on: April 26, 2013, 10:32 PM »
Ingenious :4_17_5: top skills dude :daumenhoch:
