975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 02:42 AM
RADBMX.CO.UK  |  New School BMX 2004 - Now  |  New School Park, Street & Dirt  |  170mm cranks what's the deal?
Author Topic: 170mm cranks what's the deal?  (Read 1970 times)
medved
« on: April 13, 2013, 06:24 PM »
On my search for a bike to get me rolling round the streets most of he completes seem to have 170mm cranks.
I understand the 25:9 gearing, but why the shorter cranks? Are they easier to jump/ boost with or just for a smaller rider?
Btw I ride 175s on my race bike and always have done so.  Does it make any noticeable difference  or not?
Offline Betty
Re: 170mm cranks what's the deal?
« Reply #1 on: April 13, 2013, 06:26 PM »
Makes spinning tricks easier.... allegedly  :-\
2 minutes turkish...
Offline Peter J
  • I have issues
« Reply #2 on: April 13, 2013, 06:31 PM »
I've got 160's on mine  :-\
Feel fine as I rarely pedal
Come to the I hardly ride  :-[
punkdSICO
« Reply #3 on: April 13, 2013, 06:54 PM »
:)  I know the feeling..
Paul
Offline kev-s
« Reply #4 on: April 13, 2013, 07:43 PM »
i run 170's but used to always run 180's only took 10 mins to get used to the difference
reason why alot of people run 170's is because it saves abit of weight, most new school bikes have shorter rear ends so makes sense to have shorter crank arms as when i ran 180's on a 13.75 rear end the heel of my foot used to clip the peg, now it dosent
if racing/dirt jumping then i can see the appeal of longer cranks but on a park bike they just aren't needed :daumenhoch:
also most completes are aimed at kids, who obviously have shorter legs :daumenhoch:
Offline Betty
« Reply #5 on: April 13, 2013, 07:51 PM »
Good point on the short rear end Kev
I'm running a frame with 13" rear with 175mm cranks and haven't had any peg/heel clearance issues, must be down to my size 7 feet   :-[
« Reply #6 on: April 13, 2013, 07:57 PM »
On a race track is the only place it would matter  ::)
If you are just rolling around streets or riding parks ,
where you just drop in and pump or do the the odd rev on your crank ,it doesn'r matter  :)
Offline kev-s
« Reply #7 on: April 13, 2013, 08:00 PM »
lol my size 10's used to clip the dirtbike's peg when i ran 180's on the dirtbikes 14" rear end
Offline fugazi
« Reply #8 on: April 13, 2013, 09:30 PM »
All the above & some people say You get more 'pop' with shorter cranks, as well as stiffer & less liable to bend.
« Reply #9 on: April 13, 2013, 09:36 PM »
short cranks and massive bars combined with seat/post combos make you look special
« Reply #10 on: April 13, 2013, 09:47 PM »
Another reason for shorter cranks is  is its easier to "pinch" your feet (for bar spins) if they are closer together. And it makes crank arm/pedal slide tricks easier.
Or so I have read .... :-[
Offline fugazi
« Reply #11 on: April 13, 2013, 10:05 PM »
And to add to the mix, a lot of flat riders have cranks as short as 140mm!
« Reply #12 on: April 15, 2013, 04:55 PM »
I need some 170mms for exactly the reason Kev says about heel clippage.
Offline garran
« Reply #13 on: April 15, 2013, 05:55 PM »
on my morales i had straight forks with 180 flights, kept hitting my feet on the tires and i'm only a size 7 ;D
Offline HARODAVE
« Reply #14 on: April 15, 2013, 09:21 PM »
had some 170 prolines on my OS bike and they felt great to ride , wouldnt mind giving them a go on my NS to see if i can tell the difference between them and 175's  :daumenhoch:
medved
« Reply #15 on: April 22, 2013, 10:20 PM »
Well in the end the bike I bought turned up with 175mm cranks instead! That's that then
