975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 23, 2024, 12:26 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Crupi cage bolt problem
Author Topic: Crupi cage bolt problem  (Read 747 times)
Offline neil
« on: April 11, 2013, 02:04 PM »
Thought I'd strip the colour off the cages on my crupis,but when to get me Allen keys and noticed all the cages bolts are rounded any idea how I can get em out?
« Last Edit: April 11, 2013, 02:22 PM by neil »
Offline boofy44
Re: Crupi cage bolt problem
« Reply #1 on: April 11, 2013, 05:33 PM »
you could try and cut a slot across the top of them with a dremmel or junior hacksaw.
Offline not johndub71
« Reply #2 on: April 11, 2013, 07:18 PM »
drill?
Facebook/Fr35Hair
« Reply #3 on: April 11, 2013, 07:22 PM »
Good tip  :daumenhoch:  It worked for me on some crupi's and a stubborn one on a set of XCII's . The suntour one was a bit trickier as the screw is ressesed .
Offline Peter J
  • I have issues
« Reply #4 on: April 11, 2013, 07:24 PM »
Yup
Offline Munnyella
« Reply #5 on: April 11, 2013, 07:38 PM »
once the slot is cut, put the allen key in and give it a sharp crack with a hammer to `break the seal' and hopefully make life easier with the screwdriver, make the screwdriver fit well too.
MM
« Reply #6 on: April 12, 2013, 11:36 AM »
tap in an appropriate sized torx drive and undo; trust me it works very well  :daumenhoch:
Offline adenough
  • Buzz Killington...
« Reply #7 on: April 12, 2013, 04:56 PM »
left hand m5/m6 tap :daumenhoch:
Offline neil
« Reply #8 on: April 12, 2013, 06:04 PM »
You've lost me  :LolLolLolLol:
Offline adenough
« Reply #9 on: April 12, 2013, 06:16 PM »
