975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 05:22 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  another redline flight 11 question
Author Topic: another redline flight 11 question  (Read 519 times)
selfpreservation
« on: July 27, 2006, 09:00 PM »
right fitted the flights and it says put enough washers on so the chain and freewheel are in a straight line , the problem is that i have to put loads of washers on the other side to fill the gap and it feels all unbalanced and wobbly on the left side , do i just even up the amount of washers on each side and screw the manual or am i missing something
Re: another redline flight 11 question
« Reply #1 on: July 27, 2006, 09:47 PM »
It should not feel unbalanced & wobbly, but there are usually more washers on the nondrive side because there is no chainwheel.
selfpreservation
« Reply #2 on: July 27, 2006, 09:54 PM »
might be phsycological but it dont feel good but then again i have broken ribs and havent ridden in weeks and i have a new frame and forks
« Reply #3 on: July 27, 2006, 10:14 PM »
the axle should be the same both sides when you remove the blots
selfpreservation
« Reply #4 on: July 27, 2006, 10:42 PM »
all sorted now guys cheers
