975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 07:24 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pedal Bearings Size?
Author Topic: Pedal Bearings Size?  (Read 626 times)
duncan
« on: July 27, 2006, 06:57 PM »
Does anyone know the correct size for pedal bearings? I'm trying to repair some old Maxy Cross pedals.
I bought some 5/32" headset bearings in cages that will probably do, it's just the old bearings look ever so slightly bigger.
If there is a 6/32" size (or 3/16") then maybe that's what I need. Can't find this size in local bikeshops though.
How do the sizes work, because another size up (I think they were 7/32") were way too big, they almost seem to double in size for each 1/32 increment.
This leads me to believe I'm probably stuck with using the headset bearings.
Offline sawzall
Re: Pedal Bearings Size?
« Reply #1 on: July 27, 2006, 09:28 PM »
go to a bearing supplier,they will be able to help if you have a pattern 8)
duncan
« Reply #2 on: July 27, 2006, 09:45 PM »
Thanks, I'll see if there's a supplier.
I was told I can damage the cones/cups if I use the wrong size.
They're old pedals and the parts already have a lot of wear,  but I'm as well to get the right size if possible.
adeshere
« Reply #3 on: July 27, 2006, 10:51 PM »
Hi,
I just replaced the bearing in my shimano DX pedals and these were
3.969 MM ( 5/32" ) DIAMETER
duncan
« Reply #4 on: July 28, 2006, 02:40 AM »
Couldn't contain myself, and just built one up using the 5/32" bearings from a headset race.
There were 22 bearings in the race, same as the number in a pedal which is fortunate.
I could have got another bearing in each side, so maybe they are a tad small but I think they'll do fine.
When I got the pedals they were rusted solid, good to see them spinning now.
What bikes did Maxy pedals come on? MK1 Burners?
Edit >>
I just realised, the bearings are probably the right size, it's the cups that will be worn down.
« Last Edit: July 28, 2006, 02:54 AM by duncan »
