975755 Posts in 138933 Topics by 6360 Members - Latest Member: TattooedYorkie September 23, 2024, 02:27 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  bottom bracket bearing code
Author Topic: bottom bracket bearing code  (Read 540 times)
gib66
« on: March 31, 2013, 09:41 AM »
does anyone have a set of 20mm bottom brackets.i need the bearing code for it so i can order some new nearings .they need to be for a usa bb set
Re: bottom bracket bearing code
« Reply #1 on: April 08, 2013, 10:36 PM »
Have you not got a mid or U.S. bb knocking about? Quick measure up and you're there.
A normal mid/U.S. bearing is an R12 2RS. This is imperial, the internal diameter is actually 3/4" or 19.05mm. You could bowl into your bearing house and ask for the metric equivalent of an R12 with a 20mm ID I suppose.
They might look at you a bit funny....
Offline Gary72
« Reply #2 on: April 08, 2013, 11:14 PM »
I think it's 6004.
The 2RS bit refers to the numer of rubber seals
Offline Gary72
