975882 Posts in 138950 Topics by 6383 Members - Latest Member: moley147 February 17, 2025, 01:07 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  linear slic cable question
Author Topic: linear slic cable question  (Read 908 times)
motomagII
« on: July 27, 2006, 08:24 AM »
just got 2 of these to try and see if they are beter than normal cable but i cant seem to cut em to lengththey are to strong .how do i snip em without damaging them .normally wire cutters will do the trick but not on these babies .thanks
Online BrianP
Re: linear slic cable question
« Reply #1 on: July 27, 2006, 08:49 AM »
I used a cutting wheel on a dremel to sort mine out.
It made a pretty tidy cut.
(You probably already know this, but you gotta make sure you use the replacement metal end piece on the cable outer after you've cut it, otherwise the cut end of the cable starts to slowly come apart.)
Bp.
Sanmarcopizza
« Reply #2 on: July 27, 2006, 09:21 AM »
I use a proper set of bike cable cutters and use a swift cutting motion. Normally works for me. Then I use a bradawl to re-shape the tube.
MeddlE
« Reply #3 on: July 27, 2006, 09:40 AM »
I use a set of industrial wire cutters and they handle slic linear without hassle.
« Reply #4 on: July 27, 2006, 11:14 AM »
normal pliers i used
with me vice like grip easy cutting lol
MeddlE
« Reply #5 on: July 27, 2006, 12:05 PM »
Gorilla paws eh? ;D
Offline jimwise68
« Reply #6 on: July 27, 2006, 06:42 PM »
They sure are tuff muthers.
I used some proper electricians cutters, not the ones with loads of cutting sections. (Kindly leant to me by Flaz.)
Like a hot knife through butter!  :daumenhoch:
