975966 Posts in 138957 Topics by 6396 Members - Latest Member: macbook mcnugget July 01, 2025, 07:13 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  any one running gsport hubs
Author Topic: any one running gsport hubs  (Read 1018 times)
« on: July 26, 2006, 02:23 PM »
i just replaced rear spindle and bearings but it looks a tad strange to me
or is it new school hub set up i am not use to.one side sticks out alot more than they other
Offline Wayne Ryder
Re: any one running gsport hubs
« Reply #1 on: July 26, 2006, 03:07 PM »
I've got an old Homer with the tapered spacer (on the non-freewheel side), it looks slightly different from yours. After adding a washer to the axle on the opposite side, it was pretty symmetrical. I see yours protrudes enough already, though.
I don't think yours are too far out if you were to measure in each direction from the centre of the hub.
« Last Edit: July 26, 2006, 06:11 PM by Wayne Ryder »
« Reply #2 on: July 26, 2006, 03:10 PM »
i will measure cheers chap it does fit into the frame ok.on the sprocket side the bearings are
inside the hub strange to me it has to be inserted from the other side and held in with a clip
« Reply #3 on: July 26, 2006, 03:16 PM »
i just measured it is spot on center to center :daumenhoch:
