975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 25, 2024, 03:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Stuck 3 Piece Cranks
Author Topic: Stuck 3 Piece Cranks  (Read 1046 times)
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« on: March 14, 2013, 06:22 PM »
I'm wondering / hoping someone has a tip for getting crank arms off.
So I have a couple of sets of Sugino GT cranks that i want to swap out, i've removed the end caps and bolts but the arms just don't want to budge...
Is it just a case of whacking them with a mallet or is there some sort of witchcraft that i'm unaware of?  ???
Chris  :daumenhoch:
leehunt1
Re: Stuck 3 Piece Cranks
« Reply #1 on: March 14, 2013, 06:23 PM »
Try soaking them overnight in petrol or wd40
« Reply #2 on: March 14, 2013, 06:30 PM »
you need to buy a crank removal tool chris
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #4 on: March 14, 2013, 06:51 PM »
Like every solution... Easy when you know how  :daumenhoch:
« Last Edit: March 14, 2013, 07:01 PM by Jaan »
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #5 on: March 14, 2013, 07:02 PM »
So the thread size for the crank arm / dust cap is universal across all cranks?
« Reply #6 on: March 14, 2013, 09:20 PM »
Chris
I have a crank removal spanner you can borrow if you want mate.
Let me know your address and I will send it to you.
Offline Devilock
« Reply #7 on: March 14, 2013, 09:29 PM »
14mm apart from 400's: 15mm.
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #8 on: March 15, 2013, 11:49 PM »
Chris
Thanks for the kind offer Sean but I thought it was probably best to order one.  :daumenhoch:
Offline Jaan
  • A.K.A. Chris
    • AlphaPunk
« Reply #9 on: March 15, 2013, 11:50 PM »
Aren't Profiles also different?
Offline bobbbbsy
« Reply #10 on: March 16, 2013, 12:21 AM »
rubber mallet and a good wack ..  ::)
Offline Funkyworm
« Reply #11 on: March 16, 2013, 05:52 PM »
There's nothing better than having a good wack  :buck2:
