975644
Dannygee
July 05, 2024, 10:54 AM
Mid School ( Keep the faith )
V brake problem ?
Topic: V brake problem ? (Read 1626 times)
neil
Flip-Whip
V brake problem ?
March 06, 2013, 11:37 PM »
Never fitted one before but fitted nicely onto the mounts but either the wheels is too wide or I'm being a nob! Cos there's no way I can move the arms inwards,hope this makes sense!
Discostu
540 Air
Two's Company
Re: V brake problem ?
March 06, 2013, 11:39 PM »
Put some pics up mate.
neil
Flip-Whip
March 06, 2013, 11:53 PM »
fugazi
Site Supporter
540 Air
March 07, 2013, 12:00 AM »
Looks like the frame is meant to use Canti brakes, as opposed to V's?
neil
Flip-Whip
March 07, 2013, 12:02 AM »
Thing is I've seen pics of em with v brakes
Discostu
540 Air
Two's Company
Yes I have got to agree. Maybe cantilever brakes are mean't to be used.
Can you remove the brake blocks and clip it all together. So we can see the clearance between the rims and the arms.
fugazi
Site Supporter
540 Air
March 07, 2013, 12:06 AM »
I didn't take a lot of notice before, but looking at the frame it's a Torker Yes? I have seen some on here with V brakes so perhaps it needs to be a certain type, but that looks way off!
neil
Flip-Whip
March 07, 2013, 12:12 AM »
Yep it's a torker, will take the brake pads off and take some piccys tomorrow
Discostu
540 Air
Two's Company
March 07, 2013, 12:15 AM »
Looking at the other pro st torkers on the museum the adjusting cone washers are on the outer side of the arms.
So the pad is more or less flush against the arm.
Also the pads were quite thin.
fugazi
Site Supporter
540 Air
March 07, 2013, 12:17 AM »
If it came with a bolt on cable stop which goes on the brake bridge I think You put Canti brakes on it, if not there must be some crazy angled arm V brakes out there!
neil
Flip-Whip
March 07, 2013, 12:19 AM »
It came with cantis sold em
Was thinking what you said Stu move all the brake pad washers to the opposite side of the arm and get the file out lol
HEYWOOD BMX
Reply #11 on:
March 07, 2013, 12:30 AM »
Stu is right-swap the fat/thin spacers over on the blocks.Torkers of this era were designed for `v`s not cantis.
neil
Flip-Whip
Reply #12 on:
March 07, 2013, 12:31 AM »
My builds are never simple
James I've got a shimano dx lever.....why did I write that you gave me the lever lol
Last Edit: March 07, 2013, 06:37 PM by neil
Dark Diggler
Berm Worm
Reply #13 on:
March 07, 2013, 06:34 AM »
James is correct, they were designed for V brakes, thats why there is no cable guild built into the frame behind the seatpost, you took off a "bolt on" one that was on the brake bridge I think?
You need some koolstop thin line pads on there, with the thinnest spacer nearest the rim (other way round than shown), they will work peachey then
The problem is that those rims are quite wide compared to most race rims.
lewisjb2002
Reply #14 on:
March 07, 2013, 08:03 AM »
You could try to remove the larger spacer from the brake pad. The little fat one on the brake pad side. im pretty sure that one is flat both ends and the one before it is curved to fit the mounting on the brake
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Reply #15 on:
March 07, 2013, 08:06 AM »
canti's look far better than V's anyway
fugazi
Site Supporter
540 Air
Reply #16 on:
March 07, 2013, 09:02 AM »
Looking at that pic the arms of the V's are going to stick out like feck whatever block/spacer arrangement You run?!
neil
Flip-Whip
Reply #17 on:
March 07, 2013, 06:41 PM »
Thin pads are on the way thanks to the Dark D
Will let yous know how I get on ,hopefully it should work ,really don't wanna sell the wheels due to them being very light and saucy
Jaymz
Team RAD
My life is Radbmx
I'm not FOOKING Dave
Reply #18 on:
March 07, 2013, 07:05 PM »
How wide are those rims??? 1.5 is the max I would go on there as I've seen these on BMX museum with DX v brakes here so they must fit
HEYWOOD BMX
Reply #19 on:
March 07, 2013, 08:13 PM »
The rims seem just fine.If after flipping the brake pad spacers over (the small ones on Koolstops need pulling off with pliers as they are pressed on) try moving the locating pin on the brake arm down to the middle hole.You should be OK,I`ve had DX Vs and ran them on loads of frames.
neil
Flip-Whip
Reply #20 on:
March 07, 2013, 09:15 PM »
Just been or and measured the width of the rim 4cm don't know what that makes it 1.75 I think
And I've changed the spacers round suddenly it ain't looking too bad when the other pads arrive I think it'll be spot on
V brake problem ?
