975800 Posts in 138943 Topics by 6362 Members - Latest Member: Bmxflex November 18, 2024, 10:09 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  ??? Short reach u brake ???
Author Topic: ??? Short reach u brake ???  (Read 412 times)
« on: March 03, 2013, 09:22 PM »
Is there such a thing?
Onmy stout boy I'm having to run the rear wheel way back in the drop outs, otherwise I can't get the block to reach the rim, I'm runnin an era correct dc ad990, and would want to keep the solution era correct obviously
Any ideas fellas?
Offline GavinDavis
Re: ??? Short reach u brake ???
« Reply #1 on: March 03, 2013, 09:29 PM »
How far back exactly are you having to fix the wheel Jay?  Is it pretty safe where it is?  Have you got a piccy?  :daumenhoch:
Offline Betty
« Reply #2 on: March 03, 2013, 09:30 PM »
Sounds like the brake mounts are welded on too far back on the stays
2 minutes turkish...
« Reply #3 on: March 03, 2013, 09:37 PM »
i think so too fella
Here is a pic and on this one they aren't quite right, needs a touch more to tighten the chain [which has 4 half links in it for fine adjustment]
and the chain has to be tight so it doesn't foul the top of the u brake
« Last Edit: March 03, 2013, 09:40 PM by Jaymz »
Offline GavinDavis
« Reply #4 on: March 03, 2013, 09:49 PM »
Hmmm......Does look pretty far back Jay??  Well...thinking about it, the 2-Hip Pork ran a different brake so im wondering if its designed around the same brake?
Offline fugazi
« Reply #5 on: March 03, 2013, 09:52 PM »
I've just noticed Your frame has the brake on the chainstays, all the other Stout Boy frames I've seen have them on the seatstays?! Even if You find a mid-school brake with shorter pad slots (Shimano?) another problem You'll run into will be the tyre rubbing on the brake arms if You want to run a shorter backend!
Offline GavinDavis
« Reply #6 on: March 03, 2013, 09:58 PM »
Theres a thread on the museum that I found that sort of talks about this.....This was one of the "first off" originals and apprantly they ran the brakes on both the chainstays and the seat stays.....Bit random I guess but all of the others were mounted on the seat stays after.  Possibly because of this problem?
« Reply #7 on: March 03, 2013, 10:00 PM »
It's all part of the fun
Offline fugazi
« Reply #8 on: March 03, 2013, 10:10 PM »
I know it's not era correct, but I would get either an original Odyssey Evolver, a Primo E-brake or a Revenge Industries brake. They all have the extra adjustment You need plus a bit more room around the brake arm area (the Revenge has the most in this area) If You reshaped them a little perhaps it would look a bit more mid school  :daumenhoch:
Offline Betty
« Reply #9 on: March 03, 2013, 10:21 PM »
Did S&M make these frames? They were notorious for brake mounts in the wrong place  :crazy2:
Proper do a u brake that gives plenty of room  :daumenhoch:
Offline not johndub71
« Reply #11 on: March 04, 2013, 02:00 PM »
I've come across this on my Haro X2. I bought it second hand and popped a generic Tektro U brake on it because it was a pos. With the stock chain which was stretched, that too wouldn't reach. Took some tweaking with chain length to get it right. Although you have a degree of adjustability on the drop outs, the U brakes don't unfortunately.
Facebook/Fr35Hair
