975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 11:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Peregrine HP-48s hub repairs
Author Topic: Peregrine HP-48s hub repairs  (Read 3899 times)
Offline Kaner
« on: March 03, 2013, 07:44 AM »
Gents
I have a very unhappy rear HP-48s hub, the axle hardly turns.
Is there a rebuild kit available including axel?
Anyone done this successfully before, what might trip me up when doing it?
Thanks
Re: Peregrine HP-48s hub repairs
« Reply #1 on: March 03, 2013, 07:57 AM »
are you hubs sealed or loose ball,both are easy to replace,pop the bearings out and get the number off the seal
grab some off ebay or your local bearing supplier.
Offline kev-s
« Reply #2 on: March 03, 2013, 08:57 AM »
as dan said pop the bearings out and get the number off the seal or just take the whole bearing to a local bearing supplier and they will measure it and give you some the same
as for the axle, it most likely is ok but if not then axles do pop up now and again
Offline Kaner
« Reply #3 on: March 03, 2013, 08:58 AM »
Cool, thanks Dan, I will take a look for the number, I've seen loads of bearings on eBay.
It's actually for your old Dirt Bros, beauty of a bike!
« Reply #4 on: March 07, 2013, 09:10 AM »
sorry to jump in on this thread but anyone know where I can get a replacement front axle for a pere super pro hub?
« Last Edit: March 07, 2013, 11:10 AM by ED209 »
Offline kev-s
Offline kev-s
« Reply #8 on: March 07, 2013, 11:01 AM »
if you have super pro hubs (sealed bearing) then yes but if your axle's threads are fine and its not visibly bent then you dont need a new axle just new sealed bearings
if you have semi pro hubs (loose ball bearing) then no this axle is no good
Offline Discostu
  • Two's Company
« Reply #9 on: March 07, 2013, 12:08 PM »
That axle kit is wrong guys. I have bought a Baggio one before and they are different to super pro hubs.
I'm assuming that those axles are for the earlier suzue hubs.  I was ok as I only needed the cones and axle nuts.
Here are some diagrams of what you need.  :daumenhoch:
Front axle measurements.
Rear axle measurements.
I hope this helps.  :daumenhoch:
Offline Kaner
« Reply #10 on: March 07, 2013, 04:06 PM »
So . . . I dismantled the rear hub and its buggered. There was a bearing missing and the internal cup was smashed to bits on the drive side. The other side was fine.
Other side:
Bearing covers:
Offline kev-s
« Reply #11 on: March 07, 2013, 05:48 PM »
they are loose ball hubs, so you need the correct size ball bearings, a normal threaded axle (not a sealed bearing axle) and obviously New bearing cups as one of yours is knackered
Offline Kaner
« Reply #12 on: March 07, 2013, 06:37 PM »
Thanks Kev.
Do you reckon I could salvage these parts out of a Large flange Suzue hub? Also does it need to be a rear or can the parts come out of a front (except of the axel of course)?
« Reply #13 on: March 07, 2013, 06:48 PM »
when i get home ,hopital  boo,i will grab an old hub
Offline kev-s
« Reply #14 on: March 07, 2013, 09:58 PM »
dan you hospital?
hope all is ok, hips?
not sure if a large flange suzue hub will work, gotta be worth a try :daumenhoch:
« Last Edit: March 08, 2013, 08:22 AM by kev s »
Offline Nigelb
« Reply #15 on: March 09, 2013, 11:35 PM »
Ed I've got a few front axle kits pal just give me shout. :daumenhoch:
