975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:51 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  help needed, front wheel/forks
Author Topic: help needed, front wheel/forks  (Read 734 times)
Offline stevepeanut
« on: February 09, 2013, 04:30 PM »
I am building my new bike. All my other bikes have 10mm axles and 10mm drop outs in the forks. My Haro forks are different, they have 10mm slots, then open out to bigger holes. My skyways have flat axles. I have figured out that I have to turn the axle sideways and it will drop through into the hole. But then the axle is wobbling around in the hole. I have normal nuts. Is there some sort of centraliser washer or nut that I need to get the axle dead central? I only have some standard nuts from normal axles. Here are a couple of pics incase my description doesnt make sense. I know there must be a simple solution to this, but I don't know what it is.
Offline That Swan Guy
Re: help needed, front wheel/forks
« Reply #1 on: February 09, 2013, 04:32 PM »
I had a Haro group 1 that did that. As it was NOS it came with 2 washers the sit in the drop out and make up the difference.
Like little top hat washers.
Offline stevepeanut
« Reply #2 on: February 09, 2013, 04:42 PM »
My old dk forks were the same, I bought some axle converter washers, and spent a long time filing them by hand to fit. Hopefully someone will know the correct name for them so I can search and find some.
Offline Gnarlyscoots
  • BANNED
« Reply #3 on: February 09, 2013, 04:54 PM »
Not sure if SE front drop out washers will help you out  :-\
Pork Chop BMX sells these  >>>  http://www.porkchopbmx.com/3-8-axle-retainer-safety-washer-for-GT-Dyno-Robby-forks-PAIR-38468.htm
« Last Edit: February 09, 2013, 04:55 PM by Londonhellboy »
BANNED
« Reply #4 on: February 09, 2013, 04:54 PM »
I used SE ones on my Knight and they were spot on.
  • BANNED
« Reply #5 on: February 09, 2013, 04:57 PM »
I think I might have some SE ones somewhere. I will take a look in a minute for you (when I can sneak away without the kids following me  :LolLolLolLol:  )
BANNED
Offline stevepeanut
« Reply #6 on: February 09, 2013, 05:09 PM »
cool cheers mate
  • BANNED
« Reply #7 on: February 09, 2013, 05:14 PM »
In fact bro, these might even be Haro ones, not sure......
BANNED
Offline stevepeanut
« Reply #8 on: February 09, 2013, 05:35 PM »
Spot on, what do you want for them?
  • BANNED
« Reply #9 on: February 09, 2013, 07:31 PM »
PM me your address bro and I will get them posted to you in the week okay.
I only have a couple of bikes to do now, so, apart from maybe a frame set change every now and again, I am out, so will never use them  :daumenhoch:
BANNED
Offline stevepeanut
« Reply #10 on: February 09, 2013, 09:09 PM »
great stuff, thankyou, sent you a pm
