975808 Posts in 138943 Topics by 6370 Members - Latest Member: Robertflamn November 26, 2024, 01:53 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Mongoose Supergoose Bottom Brackets
Author Topic: Mongoose Supergoose Bottom Brackets  (Read 514 times)
oldschoolstreak
« on: February 09, 2013, 02:59 PM »
Hi Guys, first time I`ve been on here so here goes !!
I am trying to find out if there is a difference between bottom brackets for a Supergoose 3 and earlier Supergooses. I have seen some which appear to have the large nut welded to them and others where the nut is seperate, if that makes sense. I read somewhere that they changed the design from 1983 onwards ? I just want to get the right one that would be original to a 1983 US spec Supergoose.
If anyone can help, that would be great.
Cheers..
Re: Mongoose Supergoose Bottom Brackets
« Reply #1 on: February 10, 2013, 10:02 PM »
I'm not sure which one is the early one ? the welded nut as you say may be the early one and then changed to a tange style one ?
grey area this one  ???
