975806 Posts in 138943 Topics by 6363 Members - Latest Member: V6 DOW November 24, 2024, 05:05 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Changing from old type chain ring/sprockets to new
Author Topic: Changing from old type chain ring/sprockets to new  (Read 479 times)
Gal
« on: February 07, 2013, 03:52 PM »
I prefer the way the new school bikes have smaller chain rings and sprockets fitted. Is there a way without changing the rear hub to do this?
By the way I have those 3 spoke plastic Mongoose wheels.
HEYWOOD BMX
Re: Changing from old type chain ring/sprockets to new
« Reply #1 on: February 07, 2013, 10:29 PM »
 :) No.
deeman
« Reply #2 on: February 07, 2013, 10:44 PM »
As James said it is not possible without changing the rear hub.It is however possible to fit small gearing on an O/S bike.How,i do not exactly know but it has been done.Spen69 has done this conversion on a Badlander.It doesn't sound as if those old 3 spoke mags will be any use to you for what you want to achieve,as well as looking disgusting!you would be better off buying some new skyways which are available with a 9t rear driver.they may be available with a coaster too. :daumenhoch:
HEYWOOD BMX
« Reply #3 on: February 08, 2013, 11:27 PM »
 If you go for a new hub you can go either 36/13 or 39/14 with a flip-flop or small as 25/9 with a cassette hub.Most hubs/wheels (inc newer Skyways) with a 9T cog will most likelly have a 14mm axle so check your dropouts or grind`em down...
